Bedding Deck Hardware With Butyl Tape - Page 20 - SailNet Community
 57Likes
post #191 of 424 Old 07-19-2012
Re: Bedding Deck Hardware With Butyl Tape
RV repair/supply shops have a similar product but may be of a bit lesser quality.Butyl tape is used extensively on RV's.
bandaidmd is offline
post #192 of 424 Old 07-22-2012
Well, read everyone's thoughts and decided to bed the 4 portlights on my Tartan 27 with butyl tape. Cleaned up the aluminum frames, bought new lexan, and off I went.
80 some degree day, so the butyl was pretty soft.
Now I know why manufacturers stopped using it. It is simple but labor intensive. Smearing this stuff on the surface takes a while and some effort. Then tightening down the screws slowly to squeeze out the excess takes some time. Once tightened, trimming the xcess is a piece of cake.
After using 4200, life caulk or whatever, I'm now a fan apof butyl!
That's if these babies don't leak!
SkywalkerII is offline
post #193 of 424 Old 07-23-2012
casey1999's Avatar
Originally Posted by cnoyes1001 View Post
Great information! I concure with countersinking. I want to order some Bed-it tape but I live in Hawaii. If anyone knows where it is avaliable locally please let me know.
Thanks,
Charlie
I am also in Hawaii and order the tape from Maine Sail- he can ship flat rate USPS box so not expensive (and you know it will be good stuff). Not sure where to buy here in hawaii (no recreational vehicles here like you would see on mainland), just easier to get from Maine Sail.
casey1999 is offline
post #194 of 424 Old 07-24-2012
My supply is on its way so I am looking forward to tackling the cleat, stanchion and two windows that are leaking. Once I am proficient and leak proof with those I will reseat the other deck hardware.
When doing the windows I will carefully countersink into the fibreglass as it is not that thick. (see interior shot looking out)
I will also place a bead of the butyl all around the window opening before placing the window.
Do I also create a countersink the holes in the plexi? Right now the screws go through a ring.
Thanks
i_amcdn is offline
post #195 of 424 Old 07-24-2012
skygazer's Avatar
Thanks
I'm no expert, but I know plastic has a large amount of expansion and contraction. I would say that the countersink (fantastic idea I must say) in the fiberglass will stop water from coming inside.
Countersinking the Plexiglas might help increase the likelihood of cracking, the biggest problem with Plexiglas. I'd make the holes in the Plexiglas slightly oversize to allow for the stresses of expansion/contraction, and rely on the fiberglass to keep the water out.
By "rings" do you mean some sort of finishing washer? That would seem like a decent idea to spread the pressure out across a larger area and help reduce cracking. I'm currently working on a Hunter 23 with Plexiglas simply screwed on, no outer perimeter trim or washers. Most of the screws have Plexiglas cracks around them, though surprisingly only one crack leaks.
skygazer is offline
post #196 of 424 Old 07-24-2012
Correct...finishing washer
i_amcdn is offline
post #197 of 424 Old 07-27-2012
Thank you very much for taking time to explain this so anyone could make this repair!
Well done and very generous to take time to teach all of us who did not know!
Rochelle
rackham the red is offline
post #198 of 424 Old 07-28-2012 Thread Starter
Maine Sail's Avatar
Originally Posted by chrisncate View Post
It's the exact same thing.
Actually it's not the same.. There are vast quality & consistency differences in butyl tapes just as there are in polyurethane sealants..
This is from a guy who bought RV tape at an RV store then bought Bed-It Tape..
"Hello RC,
Got the butyl rubber in time. Thanks for making the special trip!
Not that I didn’t believe you, but I wanted to check out the two tapes myself. They are two totally different materials. I will be tossing the butyl rubber I bought previously. If you’ll excuse the lousy video, I think you’ll spot your tape.
https://picasaweb.google.com/rmcgill...94158195187106
Thanks for the great product and for your technical tips.
Have a great weekend.
Bob
Tim R. likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #199 of 424 Old 07-29-2012
I hear you MS, but when you have the right stuff (actual grey butyl- not one of the other variations - I am completely aware of the variants that sit on the same shelf as butyl), it is the same. I have held both your butyl and "mine" in my hands and compared the two, and what I buy is 100% identical.
If it isn't identical, it's probably not actually labeled as grey butyl - it's probably one of the similar variants that sits on the same shelf. A lot of people don't know what they are actually looking at when shopping for butyl for the first time.
Fwiw
Yeah, I have bought it from rv supply stores and mobile home parts manufacturers. Typically these stores have 4 to 5 different kinds of grey butyl tape on their shelves. Each good for different applications.
I personally like the kind that can stretch and has the consistency of chewed gum. Some grey butyl tape is more like a playdoh-ish consistency and doesn't stretch well.
Like he said if you get the right stuff its all the same. I buy mine for under $6 for a 30 foot roll.
I personally will never go back to curing sealants.
chrisncate likes this.
Never sailed before. Quit my job, bought a SMALL sailboat and moved on with the wife dog and cat. Blogging about our experience Thewildjasmine.com
WildJasmine is offline
post #200 of 424 Old 08-02-2012
MS or others,
I read this entire thread and MS's instructions and I am not certain this question was ever fully answered. I am looking to rebed hardware (stanchions, cleats, etc) on a teak caprail. I intend to strip the old varnish/cetol off and bring the teak back down to bare wood. (needs to be refinished anyway) I like the idea of using Butyl tape. Can I use Butyl tape on teak? Am I better off rebedding the hardware with Butyl tape onto bare wood and then apply cetol? Or should I apply cetol first and then rebed with Butyl tape?
Thanks
sweetsailing is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
