Like Tree26Likes
  #211
Old 09-02-2012
sailortrash is on a distinguished road
Re: Bedding Deck Hardware With Butyl Tape
thanks have a rebedding project coming and i will use this info
  #212
Old 09-02-2012
dsmauney is on a distinguished road
I am very interested in the advice on resealing fixed ports that are attached with screws all around with no frame. Can I just use butyl or do I need to us it in combination a sealant?
Thanks
DaveM
  #213
Old 09-02-2012
mitiempo's Avatar
Thanks
DaveM
Do you mean they are just plexiglass or lexan without frames? If so I would use an adhesive like Dow 795.
Brian
  #214
Old 09-02-2012
Yes Mitiempo that is common for fixed lights with O'Day.
  #215
Old 09-07-2012
stiffwind's Avatar
s/v Black Prince
stiffwind is on a distinguished road
What modifications in this procedure would be recommended if I was mounting a small clete in the cockpit on a piece of mahogany that would be attached to the cockpit combing. Would you still recommend using butyl tape between the wood piece and the fiberglass combing. In other words, I want to mount a small clete to terminate a furling line, but I want it elevated about an inch above the combing for ease of use. So I made a small round piece of mahogany which I will epoxy clear and varnish just big enough to firmly mount the small clete. Then I simply planned to use four mounting bolts and drill through the wood and fiberglass to a backing plate or 4 washers so the clete, wood and fiberglass is all bolted together. Any other suggestions?
Been sailing all day with Dad, and I need a drink?
  #216
Old 09-17-2012
Martin Basch is on a distinguished road
I have stanchions that are held down with screws, not thru bolted. Can butyl tape still be used?
  #217
Old 09-17-2012
skygazer's Avatar
skygazer is on a distinguished road
Originally Posted by martin basch View Post
i have stanchions that are held down with screws, not thru bolted. Can butyl tape still be used?
+1
  #218
Old 09-17-2012
asdf38's Avatar
asdf38 is on a distinguished road
The only real condition necessary for butyl tape is that something else is fastening the pieces together - buyl is sticky but not an adhesive. In this case you have that with the screws so I think that will work...as long as you trust the screws. That's not considered a very robust method for fastening stanchions.
1979 Contessa 26
Boston, Ma
  #219
Old 09-17-2012
asdf38's Avatar
Thanks
DaveM
Like I said above, so long as the screws are adequately fastening the ports I'd think butyl is perfect.
EDIT: Maine Sail and chrisncate said the same thing a page back as well.
1979 Contessa 26
Boston, Ma
  #220
Old 09-17-2012
melody1204's Avatar
melody1204 is on a distinguished road
This was a great post - nice photos and lots of detail. Thanks for taking the time to share!
Melody
s/v Vacilando - CAL 35
For whatever we lose (like a you or a me)
it's always ourselves we find in the sea.
~ e.e cummings
You may post attachments
You may edit your posts
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
SEO by vBSEO 3.6.1
