Bedding Deck Hardware With Butyl Tape - Page 27 - SailNet Community
 57Likes
post #261 of 424 Old 05-26-2013
OPossumTX's Avatar
Re: Bedding Deck Hardware With Butyl Tape
I would contact the manufacturer to find out what it is and how it ages before using anymore of it. Everything that is sticky and works for a while does not mean that it a good bedding compound. This stuff looks to be intended for a very limited lifetime. I believe the manufacturer says 6 month shelf life.
OPossumTX is offline
post #262 of 424 Old 05-30-2013
s/v Tiger Lily
dvuyxx's Avatar
Maine, this is one of the best how to posts I've read. I am about to rebed a lot of hardware on teak rails. Is butyl tape good on wood? Is it better to remove the hardware and finish the wood ... Then butyl or better on bare wood?
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #263 of 424 Old 05-30-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I had to remove the handrails on my boat due to leaking. I varnished them while they were off with a single coat on the bottom. I used the butyl to seal it up when putting it back on the boat and have left a tarp off since and don't see any leaks or other issues with it. I think the important part is having the compression between the hardware, wood and mounting surface.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
The Following User Says Thank You to Rhapsody-NS27 For This Useful Post:
dvuyxx (05-30-2013)
post #264 of 424 Old 05-30-2013 Thread Starter
Maine Sail's Avatar
In experience you are ALWAYS better to seal the underside of the wood. If you don't this is where moisture enters and begins to lift the finish. Some of the higher end boat builders epoxy seal the bottoms of teak applied above decks...
Butyl will work either way but if you have the wood off definitely seal the bottom...
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
dvuyxx (05-30-2013)
post #265 of 424 Old 07-16-2013
Sorry if this question has already been asked. I relocated a traveler track onto superfine nonskid. I'm trying to remove the residual buytl that has gotten onto the nonskid. I've used acetone soaked q-tips - but that only gets the butyl sitting on top of the nonskid. Any suggestions on removing the buytl sitting at the bottom of the fine nonskid?
oomfh is offline
post #266 of 424 Old 07-16-2013 Thread Starter
Maine Sail's Avatar
Mineral Spirits does a better job than Acetone...
______
post #267 of 424 Old 07-16-2013
Maine Sail, I received your Tape and used it on my windows that have been leaking for 4+ years. THANK YOU it really worked. They haven't leaked in 2 months so far. Everything else will be rebedded this winter for sure. Thanks again.
P.S. My brother works for the local RV dealer and yours is better than anything he could get.
WesAllen is offline
The Following User Says Thank You to WesAllen For This Useful Post:
Maine Sail (07-16-2013)
post #268 of 424 Old 07-16-2013
rugosa's Avatar
Simple Green & Majik Eraser - works like magic!
rugosa is offline
post #269 of 424 Old 07-22-2013
oceangirl's Avatar
I've read at least 19 pages, sorry if this has been asked and answered.
First, FANTASTIC article Maine Sail, pure gold!
I was wondering if anyone in the tropics, have issues with butyl "running" a bit.
If so, what solutions have you come up with? Is butyl compatible with other caulks? Maybe caulk a perimeter thin bead of something like 4000uv to "skin" or form a barrier to the butyl? Crazy talk?
Why not get the black butyl? Is this due to tracking it around the boat?
Side note: I've used 3Ms take on butyl tape strip caulk(http://multimedia.3m.com/mws/mediawe...DS_08578_P.pdf ), I liked it, bought it from Bluewater ship store in Texas. Did very well but I only had the boat another year after that work. I will find out how well it stood up when i see the boat in a couple weeks, I haven't owned the boat in 13 years.
Again, sorry if this has been explained already. Great thread.
~~Ocean Girl~~
~~Mrs. Rain Dog~~
1989 Pacific Seacraft Crealock 34 Hull# 142
oceangirl is offline
post #270 of 424 Old 07-22-2013
asdf38's Avatar
Good question, I'd like to see the answer. I applied lifecaulk polysulfide over butyl tape on my chainplates just this season and I'm not sure if that was smart yet or not. I didn't want to leave the butyl entirely exposed to UV/dirt etc.
asdf38 is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
