Bedding Deck Hardware With Butyl Tape - Page 29 - SailNet Community
 57Likes
post #281 of 424 Old 10-01-2013
davisr's Avatar
Re: Bedding Deck Hardware With Butyl Tape
Good deal Maine. Many thanks for the tips. Will place an order for your top notch butyl as soon as I can get a good estimate for the total feet I'll need. Will be rebedding not only all the deck hardware (and genny track), but also the portlights. Though it's only 25 feet overall, I can imagine that I'll need more than I'm currently estimating off the top of my head.
Roscoe
Ericson 25, #226
Oystercatcher
davisr is offline
post #282 of 424 Old 10-27-2013
TakeFive's Avatar
I have a transom-hung rudder, with two gudgeons mounted on the transom. When I replaced them last year I bedded them with MaineSail's butyl tape, since they are both above the waterline. I cranked down on the screws as much as I could, but toward the end of the season they loosened up. These things have big bronze backing plates and lock nuts, so I know the screws did not loosen. The butyl apparently oozed out enough for the bedding to become a little thinner.
Is butyl the right application for this, or should I look for a curing sealant to bed the gudgeons? If the latter, what would you recommend?
FWIW, I am replacing the Phillips head bolts with hex head, so in the future I should be able tighten them up mid-season without having to remove the rudder.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #283 of 424 Old 10-28-2013 Thread Starter
Maine Sail's Avatar
This is why I stress over, and over, and over again tighten SLOWLY, WAIT, TIGHTEN SOME MORE, WAIT, TIGHTEN SOME MORE... when the butyl STOPS oozing then the fitting is tight. The larger the fitting the longer the process..... The butyl did what it is supposed to do, the just missed installer a step.. keep tightening until it stops oozing and you'll be fine.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #284 of 424 Old 10-28-2013
TakeFive's Avatar
That's what I did for a few days, but I had to stop tightening after installing the rudder because it prevented me reaching the bolts with a screwdriver. Hopefully with the hex heads I'll be able to continue tightening after the rudder is re-installed.
TakeFive is offline
post #285 of 424 Old 10-28-2013 Thread Starter
Maine Sail's Avatar
You should not need to take it apart and start over unless you want to move to HEX. Sometimes placing a heat lamp on the parts can accelerate the displacement portion of the project from a few weeks of spread out small tightening events to a couple of days.......
I once had a t-top / tower install on a sport fishing boat that took three weeks to stop displacing. Owner kept insisting we were done yet I would keep telling him we were not, these bases are quite large. When he would check on it in a few days it was still slowly displacing. I know there is a tendency to stop tightening because it may feel tight but this product is purposely quite dense as the displacement step forces the butyl into every nook and cranny and keeps it in tension.
I can also tell you that deck core, even when dry, will CRUSH, before Bed-It Butyl Tape is fully displaced, if you take it too fast... It is purposely designed to flow like Molasses up hill in January, just be patient with it...
______
post #286 of 424 Old 10-28-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I can now understand the need to wait during tightening.
I took my deck handrails off for refinishing/rebidding earlier this year. I reattached them while it was still starting to warm up. I tightened the bolts and as the weather warmed up, the butyl would ooze out more as it warmed up. I haven't seen any leaks since.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #287 of 424 Old 10-28-2013
TakeFive's Avatar
I definitely want to move to hex head bolts. I've never been happy with the Phillips head bolts.
But I wasn't planning to start over. I was just going to remove and replace one bolt at a time, so that I never fully released the compression. Do you think that is good enough? Or do I need to pull them off, clean, and start over with another too-thick bed of butyl?
TakeFive is offline
post #288 of 424 Old 10-29-2013 Thread Starter
Maine Sail's Avatar
It does not sound like you've read the instructions or fully understand the process. You need to bed the items as a single process not as a single bolt. What is under the plate is only PART of the seal what is around each bolt IS the seal..... How are you going to butyl-cone each bolt then push it through.....?
I may suggest re-reading the instructions:
Re-Bedding Instructions
______
post #289 of 424 Old 10-31-2013
Chastened
Ajax_MD's Avatar
I finally bought the "miracle butyl" yesterday.
I have never been so freaking excited about tape or sealant.
Something is definitely wrong with me.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #290 of 424 Old 10-31-2013
TakeFive's Avatar
It does not sound like you've read the instructions or fully understand the process. You need to bed the items as a single process not as a single bolt....[/B]
I had read and followed your instructions when I originally installed the new gudgeons, but I had since fogotten this detail. After having re-read your instructions, I'll remove the gudgeons and rebed from scratch. Note, however, that I cannot avoid twisting the bolts because they have a single threaded backing plate. The only way to tighten them is to twist the bolts. There are locknuts behind the backing plate, but they serve only to keep the screws from loosening from the backing plate.
TakeFive is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
