Bedding Deck Hardware With Butyl Tape - Page 31 - SailNet Community
 57Likes
post #301 of 424 Old 12-05-2013 Thread Starter
Maine Sail's Avatar
Re: Bedding Deck Hardware With Butyl Tape
Originally Posted by axel View Post
What about bedding deck hardware to an old teak deck? Still use butyl? What would you seal the teak with?
It is used for this all the time and works very well. Also cleans off the teak easier than polyruethanes which tend to take half the deck with it when you remvoe them..
A teak deck is most always left to age natural silver so it is not slippery. Some use teak oils on teak decks but they can become slick in nasty weather......
christian.hess likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #302 of 424 Old 12-06-2013
christian.hess's Avatar
sorry if this is not kosher to do...but I dont think they will let me import this wonderful product down here for cheap
so even though its black I have found some down here...sorry if I have missed it but can this work even though I cant confirm its the same quality as used here?
thanks
copacabana likes this.
christian.hess is offline
post #303 of 424 Old 12-06-2013 Thread Starter
Maine Sail's Avatar
thanks
It will "work" but the questions will be:
For how long?
Will it bleed and continue to bleed when hot?
Will it stain?
Will it remain flexible enough to keep the seal when it is 1/64" thick?
How is it affected by typical cleaning chemicals?
I have tested over 40 brands so know that very few of them can meet my standards. I can't have even hazard a guess as to how that product will perform as there are vast differences in how butyls perform...
Blacks usually have okay stretch performance but are darn messy and tend to bleed longer....
My shipping down there is quite expensive so I would say to try it. You can also re-do easily because unlike a PU sealant is will not be near permanent... You really have nothing to lose by trying it...
______
The Following User Says Thank You to Maine Sail For This Useful Post:
christian.hess (12-07-2013)
post #304 of 424 Old 12-06-2013
Thanks Maine Sail!
I prefer the teak silvered, so I won't oil it or try to treat it in any way. But the question was whether I should seal the teak under the hardware to ensure adhesion for the butyl.
When I take off the hardware for rebedding (genoatracks, chainplates, stanchions, etc.) I could apply epoxy or varnish to the parts of the teak that will afterwards be covered. Earlier in the thread it has been recommended to seal wood before attaching with butyl as sealant. However, none of the cases referred to mounting hardware on a teak deck, which is why I asked my question.
As I stated, the teak deck is old and weathered, and previous owners have sanded it down, at least once, without taking off the hardware. Thus, the genua tracks and other stuff stands a bit proud, a couple of millimeters above the rest of the deck. When I take the hardware off, it is therefore easy to sand off a little, to ensure all previous sealant has been removed. That of course freshens the teak. So the question is really if the butyl will adhere well to this fresh teak, or whether I ought to seal it somehow.
Sorry for being so longwinded, I just want to be sure that my question is clear. And thanks a lot for you help in this thread and elsewhere on the net!
axel is offline
post #305 of 424 Old 12-06-2013 Thread Starter
Maine Sail's Avatar
Thanks Maine Sail!
You can seal it if you want to, but you don't need to...
______
axel (12-07-2013)
post #306 of 424 Old 12-07-2013
For how long?
Will it stain?
maybe I read wrong do you mean shipping is quite expensive or INEXPENSIVE? jajaja
maybe Ill have to bite the bullet
thanks bud
christian
post #307 of 424 Old 12-09-2013
That was great thank you
Again.
svhandy is offline
post #308 of 424 Old 12-10-2013
thanks
Christian, I found myself in the same position here in Brazil. I couldn't find butyl tape anywhere and at the time Mainsail didn't ship here. I ended up finding it through a Sika dealer (they are strong in Latin America and they have a dealer in El Salvador). The product is called Sika Lastomer (I forget which product number exactly, but look on their site- it's the pale beige tape clearly described as a butyl rubber based product). It is excellent stuff and you might be able to find it in El Salvador. I ended up having to buy a whole box (24 rolls!) as the local dealer couldn't order less, so if you ever head down to Brazil I have some for you!
oldfurr and christian.hess like this.
Vindö 50
copacabana is offline
The Following User Says Thank You to copacabana For This Useful Post:
christian.hess (12-10-2013)
post #309 of 424 Old 12-10-2013
someday Ill cruise to brasil...for now...that info is woth gold!
thanks so much copa and and mainesail
christian
post #310 of 424 Old 12-29-2013
I am bedding various pieces of countersunk hardware on a wooden deck: jib tracks, pad eyes, stanchions, etc. But I am unable to follow Mainsail's tutorial because the bolts are threaded through the deck and so I have to turn the head of the screw in order to screw it through the deck to seat it…which scrapes off the butyl as it seats in the hardware.
Should I enlarge the bolt holes in the deck slightly so that the bolts can be inserted with out turning them?
justonemoreproject is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
