Bedding Deck Hardware With Butyl Tape - Page 36 - SailNet Community
 57Likes
post #351 of 424 Old 07-19-2014
budvar's Avatar
Re: Bedding Deck Hardware With Butyl Tape
I bought a roll from MainSail last year, wondered the same thing as you are right now.
I can't tell you how glad I am to have a roll hanging around. I've dipped into it so many times for different projects. Guess what, still have a fair amount left for more projects. Like the guy above said, it doesn't wear out.
Chris
US Yacht 25 "Chinook"
Kennewick, Wa.
budvar is offline
post #352 of 424 Old 08-19-2014
robertluster's Avatar
MANY Thanks, I now feel confident and competent for the task... And will have to do it ONCE. Excellent info and pictures - I hope I can find other articles as good for the other tasks awaiting me as a new owner...
robertluster is offline
post #353 of 424 Old 08-20-2014
I make sawdust
thereefgeek's Avatar
+1.
Thanks Mainesail. Ordered your tape, and installed per your instructions last year (after first over-drilling and potting with epoxy).
No leaks.
Why would anyone second guess something that has already been proven in the field?
Two words: El Cheapo.
Not worth the hassle. Just buy the good stuff and follow the detailed instructions, and then Mainesail won't have to answer a bunch of stupid questions online...
Simple as that.
therapy23 and mitiempo like this.
-Rich VanDusen
1977 Tayana 37 Hull #91
Ramble On
thereefgeek is offline
post #354 of 424 Old 10-09-2014
This is a superb tutorial with excellent photographs, thank you. One question:
Should I line the entire underside of my genoa track (all 3m of it) with tape or can I get away with just doing the bolts? I've done my stay-sail track already with just tape around the bolts and it was easy to do, but only afterwards did it occur to me that perhaps I should have lined the underside.
I recorded me installing my stay-sail track, which you can see here (note that I now have white tape to do the rest of the fittings and I will not be screwing down the bolts just to put them in place as you see here). Jump to 2:08 minutes in:
On various youtube clips I've seen stanchion bases bedded with tape just around the bolts, not the underside of the fitting.
Any thoughts?
demonboy is offline
post #355 of 424 Old 10-09-2014
mitiempo's Avatar
Bed the entire fitting. You don't want water anywhere underneath any item. For one thing in northern areas it can freeze, causing undue stress on the attachment.
Brian
mitiempo is online now
post #356 of 424 Old 10-09-2014
Here's the issue though: for every bolt hole there is a hole for the car to lock into. That goes all the way through the track. If I seal the underside that hole remains filled with water.
demonboy is offline
post #357 of 424 Old 10-10-2014
budvar's Avatar
I'm a total nitwit with search function, so pardon if a repost:
I'm a total convert with butyl for rebedding. However, had one instance where it didn't seem the good solution. Used a wood base to raise a cheek block. I did everything else right....drill holes in deck...dremel then re-epoxy holes.
However, the butyl wouldn't stick or conform to the wood, at all. It was mahogany, with a linseed oil finish. Could it have been the finish? Ended up having to use the dredded 3-m product. Thanks for any feedback.
Chris
Kennewick, Wa.
budvar is offline
post #358 of 424 Old 10-10-2014
Asleep at the wheel
jimgo's Avatar
Budvar, I would bet it was the finish. Not much sticks to oil (which is, actually, why you used it in the first place, though that may not seem immediately apparent).
Demon, I think you want tape under any portion that is around/near the deck penetrations. For the track, there may be drainage areas for some of the track holes (the ones that aren't screw holes). I'd probably do around those so there is good drainage. That being said, water being trapped in an open space isn't really a problem. If it freezes, it will expand out of the space, so no biggie. If it's trapped in a confined space (think of water that has wicked into the cellular structure of wood, for example), then as it freezes it expands and distorts/wrecks the space.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
budvar (10-12-2014)
post #359 of 424 Old 10-15-2014
al brazzi
I have read most of this highly informative post, skipped the middle just for time sake. I have some deck leaks in a new to me CS30 1987. I will start pulling panels and hosing it down but can someone tell me if my Boat was sealed with the Butyl I did read CS used it to a point, after that what did they use ? I (hope) its the Genoa tracks since I'm sure they are past the recommended rebedding cycle but are there other trouble areas that may be more likely the cause. There is a noticeable amount of leakage either when sailing to weather or during a hard rain. Its NOT the chain plates.
Although belated thanks to Maine sail for a truly knowledgeable post.
FWIW I'm not new to Sailing but I am new to leaky boats.
albrazzi is online now
post #360 of 424 Old 10-15-2014
Bristol 45.5 - AiniA
You should be able to reach up inside the hull-deck joint and feel around. if it is butyl tape it will still be quite soft and rubbery.
oldfurr likes this.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
