Bedding Deck Hardware With Butyl Tape - Page 6 - SailNet Community
 57Likes
post #51 of 424 Old 11-22-2010 Thread Starter
Maine Sail's Avatar
Originally Posted by mitiempo View Post
I'm sure other builders have used butyl as well.
Sabre did too. It is hard to find because even the glazing industry has moved towards adhesive sealants. Butyl is more labor intensive to do it right, hence the move buy builders away from it. The rolls also collect factory dust if not kept clean something they don't have to worry about with gun injected goop..
It took me months to find the "right stuff" that the builders used to use because the glazing and RV industries are now using a slightly different material, still butyl but not the same consistency...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #52 of 424 Old 11-22-2010
LakeSuperiorGeezer's Avatar
Look up Recreational Vehicles in the phone book, call and ask if they have butyl tape. Most do.
LakeSuperiorGeezer is offline
post #53 of 424 Old 11-22-2010
mitiempo's Avatar
In my area (Victoria) there is no problem finding gray butyl in hardware stores at $5 or so a roll.
Brian
mitiempo is offline
post #54 of 424 Old 11-22-2010
Pearson 303
SVCarolena's Avatar
MS - can you give us a source for the butyl you are using? I purchased a roll from an online RV dealer about a year ago and after lots of rebedding projects I'm almost out and about to place another order.
SVCarolena is offline
post #55 of 424 Old 11-22-2010
Back to just the Jon boat
therapy23's Avatar
Well crap!
It took a bit to get mine.
Now I don't know. It is grey. It came from a RV place in Tampa - world famous Lazy Days. , Well, the store next to it anyway.
therapy23 is offline
post #56 of 424 Old 11-22-2010
Learning the HARD way...
eherlihy's Avatar
You can get it directly from MS!
SailboatOwners.com - Marketplace - Category - For sale - Bed-It - Butyl Bedding Tape
Disclaimer: No financial interest in MS... but grateful for all that he's done for the community.
[EDIT:] I just checked the link above and could not find the advertisement that I originally referenced. I did some poking around and found this from Maine_Sail;
Guys,
I will be away on business from Jan 28th through about April 25th. During that time I will not be able to ship butyl tape.
I will resume shipping the butyl when I get back. The tape I sell is not readily available but there are some products out there that can work OK. If you need it fast you might need to buy another type of butyl tape from another an on-line source. As always use gray and not black!!
This may explain why he has been so quiet lately...
eherlihy is offline
post #57 of 424 Old 02-02-2011
casey1999's Avatar
Deck Hardware using Butyl Tape
Maine Sail,
In the slides it looks as if the cleat was aluminum using stainless steel bolts. Will the Butyl provide proper isolation between the two materials to prevent corrosion?
Thanks for your presentation on Butyl Tape
casey1999 is offline
post #58 of 424 Old 02-02-2011
Barquito
Barquito's Avatar
Barquito is online now
post #59 of 424 Old 02-02-2011
What ever you do, do NOT get the black butyl rubber tape... you will regret it... Get the grey or white stuff.
sailingdog is offline
post #60 of 424 Old 02-06-2011 Thread Starter
Maine Sail's Avatar
Guys,
Based on some good questions I've had I made some major changes to the original post and made it much more detailed with a LOT more photos.
You might want to go back and check out the changes...
marcberoz likes this.
______
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
