Old 04-06-2010
j24noob is on a distinguished road
Removing vermiculite in a J/24
What happens if I choose not to remove the vermiculite in a J/24? Is this an option if I don't plan to race? Do very bad things happen making the boat harder to maintain?
Old 04-06-2010
Where is the vermiculite and what purpose does it serve? Be aware that vermiculite is often contaminated with asbestos and if you're working with it, proper respirators should be worn to protect yourself.
Old 04-06-2010
The vermiculite is under the main cabin sole and aft and also in the keel sump to support the keel bolts. There are many articles and links re: the process of removing the vermiculite in J/24s, but I'm wondering if people remove it because it brings unnecessary added weight for racing, or if it poses some long-term structural integrity problems or other issues.
Old 04-06-2010
tommays's Avatar
Well
As all the boats that do serious racing are weighed and have to use corrector weights there is nothing to be gained other than making the boat safe
The bad thing is there is NO bilge in a vermiculite boat compared to a good size one in non-vermiculite boat
The is what WAS used to Stiffen the Hull and keep the keel from flexing the keel sump and cracking
After about hull 1900 it was not used and it was done with more glass and reinforcement
I have seen many J24s with DRY AND SOLID vermiculite and there fine BUT if its Wet and mushy the keel will move around and FAIL at some point
If you have a trailer with jack pads you can lift the boat on it and a bad keel WILL move around by hand
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-06-2010
Thanks for the info. It was very helpful.
Old 04-07-2010
baileyrace is on a distinguished road
The Mushy Vermiculite Problem
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
J/24? mgarbaus Boat Review and Purchase Forum 14 09-07-2003 12:04 PM
J/24 Silver Anniversary SailNet Racing Articles 0 04-17-2002 08:00 PM
Looking for J/24 owners in Chicago: Frenzy Racing 0 07-17-2001 06:20 AM
How We Won the J/24 Worlds Brad Read Racing Articles 0 10-29-2000 07:00 PM
