04-06-2010
I'm guessing that the mainsheet is end-boom sheeted at the moment. If you were to move the traveler forward to the cabin top, you'd likely need to upgrade to a heavier traveler track and increase the purchase on the main sheet, since it would be mid-boom sheeted now and would need to bridge the companionway, which your current traveler is probably not capable of doing safely. You'd also have to make sure that the boom you have is sufficiently strong to handle the loads of a mid-boom sheeting setup.
One simpler fix would be to move the traveler aft a couple of inches.  That would prevent the tiller from hitting it, and still leave the main sail end-boom sheeted. It wouldn't require new hardware either.
