Electronic charting without a serial port... - Page 2 - SailNet Community
post #11 of 22 Old 03-04-2003
There may be another driver needed to make the program use the USB port.
Sailmc is offline
post #12 of 22 Old 03-12-2003
HANUMAN
RobGallagher's Avatar
I have the same problem. My new computer does not have a 9 pin plug to connect my garmin gpsmap 76. I have tried 3 USB to 9 pin adapters. 2 of them supposedly where winxp compatable but had issues. I could not get the one that did not cause problems to be recocnised as a com port. I''m begining to think it would be easier to buy a sextant and take a class.
If you solve your problem, please let me know how you did it!!
Thanks
RobGallagher is offline
post #13 of 22 Old 03-12-2003
Someone told me that he saw a new laptop with 4 USB ports, has anyone seen one of these, and if so what kind is it?
I use a program called NavPak which set up easy on my USB port using an adapter cable and driver disk from RadioShack.
The program will acknowledge any COM number from 1 to 8, and it will talk to 4 ports simultaneously to integrate instruments without a multiplexer. Regards, John F.
pspsail is offline
post #14 of 22 Old 03-17-2003
If of interest, I guess someone from another BB saw my question about whether there was a laptop that has 4 USB ports and emailed me the below information.
... ECS makes a good laptop with 4 USB...
http://www.desknote.net/a928.html
good machines with user replaceable hard drive, RAM, CPU, CD ...
pspsail is offline
post #15 of 22 Old 03-20-2003
Hi All, same problem here in The Netherlands, got a new laptop, after being convinced by supplier there was a serial-port.
Not!!(still mad)
I''ve been searching thru the www, and found a device that slides in the PCMIA-port(hope i spell this correct), this converts, PCMIA-port to serial-port, easy to install hot-plugable.Brand is Silicom, but others have become available since, did cost about $100,= then( 1,5 years ago).
Hoping this helps.
Marc
SV Hobgoblin
The Netherlands
Hobgoblin is offline
post #16 of 22 Old 03-29-2003
Garmin actually markets a very nice Usb-serial....works like a champ...have used with many different Laptops and Gps''...good luck
www.georgesme.com
nmea2020 is offline
post #17 of 22 Old 03-29-2003
HANUMAN
I just purchased garmin''s USB-RS2323 adapter. It works, but I''m not on all aplications in the US Lights and Waterways software. I can''t say I''m overjoyed with it. It''s really designed for something else and I''m sure it''s not manufactured by garmin. It has a 9 pin male plug on one end but it also has screws to hold it down as does the female 9 pin end of the garmin cord. BARELY worth the 50 bucks, but it will get the information to your GPS.
MY COMPUTER SAY''S ITS NOT XP CERTIFIED
post #18 of 22 Old 03-30-2003
The Dell inspiron line has 9 pin serial port. I have been using it with my maptech offshore navigator software for 2 years connected to either my Garmin 3 or 48 without any problems. It works great. Garmin provides the wiring diagram for the connection to the 9 pin connector. The wiring takes about 10 minutes of soldering.
Hope this helps. I also have limited tech, knowledge, fortunately all of the wiring was color coded.
rads is offline
post #19 of 22 Old 04-14-2003
A friend of mine sent his computer to me with the same complaint. I had to reome windows XP and install windows 2000 Pro in order for the USB to serial port to work correctly. Once that was done and the Capn Voyager was installed it found the GPS data on Comm port 5. Works great now, in fact we are using the second USB port with another serial adapter and interfacing to a pactor modem which is also working fine on Comm port 7.
steve426 is offline
post #20 of 22 Old 04-20-2003
I bought a Keyspan UBS serial adapter to hool up a Garmin 45 to my Gateway laptop which worked pretty well.
emadden is offline
GPS and electronic charts question? Jhooley General Discussion (sailing related) 3 04-28-2006 10:06 AM
GPS and electronic charts? Jhooley Gear & Maintenance 4 03-18-2004 05:52 AM
Minimizing Taxes; Hailing Port kc_cmc Boat Review and Purchase Forum 14 03-04-2004 06:40 PM
sealer for bronze port twilk Gear & Maintenance 2 10-28-2003 09:48 AM
