Replacing deck fill port - that thing is really on there - SailNet Community
post #1 of 8 Old 04-07-2010 Thread Starter
Glad I found Sailnet
Bene505's Avatar
I have a deck fill port that I can't open. In fact, I tried using a ladder whil on the hard, using an extension tube over the "key" for more torque. And the very helpful pump-out guy in Martha's Vinyard tried his best and managed to get the *other* stuck port open, but couldn't get this one open either. (He did this on his own, without my asking. That's how they are on MVI.)
Is there a secret way to get that thing open? (I already tried PB Blaster, no luck.)
Barring that, it's really on there. I'm guessing they used 4200 or maybe 5200. Has anyone replaced on of these? I'm thinking about drilling through the top cap and then using a sawzall to gut outward toward the cap's threads, getting close to the threads and then using a chisel to get the pieces out. (The hose to the water tank is already detached on the underside, so nothing would get into the water tank.) Maybe I can salvage the fitting that way and just replace the cap itself.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #2 of 8 Old 04-07-2010
get a can of super duster for a computer, turn it up side down and spray the heck out of the center of the cap, freeze that sucker solid. then try to unscrew it. if it does not work then try heating it slightly with a torch, ie cycle the it from one end to the other a few times. then try is again when it frozen, if it wont let go then freeze it some more and take a ball peen hammer to the center of the cap. this should pop the center of the cap then try a chisel to break it up some more till you get the pieces out.
scottyt is offline
post #3 of 8 Old 04-08-2010 Thread Starter
Bene505's Avatar
Thanks Scotty, that would sure beat the brute force method.
Maybe I can get ahold of some liquid nitrogen. (I used to work with liquid nitrogen years ago.) Heating the port from underneath with a blow torch while aplying liquid nitrogen to the center of the fill cap would be about as extreme a use of metal expansion/contraction as I could get. And the center of the cap is a socket for a winch handle-type wrench/opener - perfect for containing some liquid nitrogen.
It's a 2-person job. 3-person if we make a video or get good pictures to post.
Regards,
Brad
Bene505 is offline
post #4 of 8 Old 04-08-2010
If the fitting is such a problem, why not just replace it. It only takes a short time to do so, and the amount of time saved is probably worth the cost of the new deck fill.
sailingdog is offline
post #5 of 8 Old 04-08-2010
sd is right about replacing the whole thing, unless it is so glued in it would damage the deck trying to get it out. and now we said damage i would not use nitrogen that might be too cold for the deck and make it too brittle.
i would give it the freeze heat cycle for a little if that does not do it replace it
scottyt is offline
post #6 of 8 Old 04-12-2010
Emerging Sailor
erikdj's Avatar
I second replacement. I just replaced two water deck fills on my 1979 cruiser. The port side one was so corroded that it broke into 3 pieces as I was trying to remove it (at first with just my hands and then with a chisel to get the rest out). All in all, it could have been a day's work except that I decided to chamfer, route and fill the core with epoxy before rebedding the new fills. But even with epoxy drying, it was basically a 2 day job.. Done.. And now the fills are shiny, new and will probably outlast the rest of the boat. :-) Plus these new models don't require a key (something that invariably gets lost or dropped in the water).
BTW, it was my first "real" repair job. And thanks to this forum, I was smart enough to follow good procedures and use butyl tape instead of one of those hideous cement products (Which I think the PO used to install the waste pump out).. eek
E
erikdj is offline
post #7 of 8 Old 04-12-2010
The Elephant
smackdaddy's Avatar
Bene, I ran into the same problem with my Waste deck-plate. It hadn't been touched in years and was basically welded with corrosion. I ended up pulling the whole assembly off the deck, taking it home, soaking it in WD40, then mounting it to a piece of plywood, drilling out the plate wrench holes, through-bolting a pipe to the cap, blasting it with a blowtorch...and it came off...eventually.
I then filled the holes with sealant and put it all back on the boat.
Now, I did all this because I refuse to spend any real money on this boat. It's just for play and for learning how to deal with crappy systems.
If it were a real boat, I'd replace the damn thing.
smackdaddy is online now
post #8 of 8 Old 04-12-2010
Emerging Sailor
erikdj's Avatar
Don't let your lady hear that!
erikdj is offline
replacing non skid on large repaired (deck) surface geary126 Gear & Maintenance 4 09-30-2006 04:33 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Inspecting and Replacing Lifelines Sue & Larry Gear and Maintenance Articles 0 05-03-2002 08:00 PM
Replacing Teak Decks Dan Dickison Gear and Maintenance Articles 0 06-04-2001 08:00 PM
