04-08-2010
You really want to have some clearance so as not to create a hard spot along the hull where the bulkhead is touching it. That will lead to the hull laminate flexing and hinging at a specific spot repeatedly and cause it to fatigue and fail there.
Originally Posted by scottyt
i would use a few more layers and when done putting it all on put some plastic ( saran wrap, trash bag etc ) over it and use a plastic squeege to remove as much resin as possible. then when cured remove the plastic, this will make it as solid as possible, as the strength is the glass not the resin. maybe even dont do the clearancing where the tabbing is going. a high resin % is weaker, and the clearancing will make it hard to not have too much resin in the gap. but feel free to have clearance where there is no tabbing
