04-08-2010
Moderator
When the engine is not in use, you should remove the key from the "ignition" or panel switch. If you're away from the boat, store it belowdecks. If you're out sailing, hang it somewhere handy. We loop ours over the transmission shift to remind us to take it out of reverse before starting.
Underway with engine running, usually things are a bit more stable/even keeled, so you should be less likely to bump it. But if there's something about the ergonomics of your cockpit that makes it more likely to hit it even when just motoring, then you might need a guard of some sort.
I bet we'll hear some good suggestions on panel guards. Some folks just mount a hinged piece of clear acrylic over the whole panel.
