Old 04-09-2010
preservedkillick is on a distinguished road
Got the shaft out, what to look for?
I'm replacing the cutlass bearing and have the shaft out. What exactly should I look for to determine that it is still good? The shaft is 7/8 bronze, around 26 inches in length and could be 45 years old for all I know.
I don't see scoring that I can actually measure with my tools, there is some very slight scoring here and there, very little where the shaft passes through the stuffing box. What is considered significant?
Straightness. I put the shaft on a machinists granite alignment table and can measure gaps between the shaft and table of less than 4 thousandths of an inch in a couple of spots. These areas appear to be slightly oval rather than bent along the length. I do have a slight bend in the threaded portion right at the last half-inch likely from the prop puller getting the stuck propeller off.
Another issue is the zinc leeching from the bronze, correct? Although I have no way to measure that.
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 04-09-2010
tommays's Avatar
Its one of the issues i am decideing on right now in my restore
The shaft was running good BUT there is a bit of wear in the stuffing box and cutlass area and i found places like this
Prices New Shafts ~ Proper Pitch - Marine Propeller, sales and service, marine boat propellers, shafting and drive train sales and reconditioning services, Selbyville, Delaware, Mid Atlantic USA
That seem to do a nice job a a fair price
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-09-2010
Do all marine diesels have gear reductions? If my engine is turning at 2700 rpm, how fast is my shaft turning?
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 04-09-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
redness, swelling, discharge...
Uh, nebbermind.
I gotta stop answering by just reading the titles of threads.
Seriously, 4 thou sounds like it is within spec. Run a die over the threads and see if the appearance of bend on the tail end of the shaft disappears.
Old 04-09-2010
I did run a die over the threads to clean them up and it did nothing to straighten the tip. I didn't put any lateral pressure on the die though. I'm hoping that since the bend at the tip is past the prop it won't effect anything.
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 04-09-2010
What is your transmission gear ratio???
Old 04-09-2010
Sailingdog,
Just looked through the manual. Specs on all sorts of things, nothing about gear ratio. The manual does elude to the fact that it is a Hurth Gearbox though. I'll see if I can find out more when I go to the boat tomorrow.
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 04-09-2010
Look for a stamped metal label on the engine or transmission. It will usually have the gear ratio printed on it.
Sailingdog,
Old 04-09-2010
BELLATRIX1965's Avatar
Maine Member
BELLATRIX1965 is on a distinguished road
Your HURTH is probably 1.5:1, or 2:1, or 2.5:1. As sailingdog says - check the nameplate. It should be on top of the gearbox, usually on the STBD side of center. I'm guessing that yours is 2:1, so the prop is turning half the speed of the engine. Dezincification (yeah, spell THAT three times fast) is often indicated by pitting in the surface or splotchy discoloration in the surface. I wouldn't worry about a slight bend in the shaft as long as it is AFT of the prop and the prop nuts. If in doubt, have a (reputable) marine machinist check it. Good luck!
Pulling E-42 prop shaft xort Endeavour 0 01-25-2010 10:49 PM
Getting the coupling back on the shaft... in the water paul77 Gear & Maintenance 4 11-23-2009 12:50 PM
Rudder Shaft Lube chs1517 Gear & Maintenance 4 11-15-2009 10:59 AM
Shaft replacement or ''the shaft''? foxglove Gear & Maintenance 4 08-18-2006 11:16 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
