04-10-2010
I use 80 grit to sand for filler/epoxy, 220, for prime coats, 300-500 grit for paint finish, 1500- 2000 for polishing if applicable. I don't use above 500 grit for adhesion reasons. If you use a random orbit for your final sand before paint, you will probably be able to see swirls through the finish. Therefore, maybe it would be a good idea to wet sand your final primer coat before paint. A good trick when doing this is a spray bottle of warm water with a small amount of dish detergent, as you sand a section, use a rubber squeegee to dry off where you have sanded, you will see small imperfections easily, and if you take your time, and even out all the highs and lows, you will achieve the best result.
Why, why, why? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
