Old 04-09-2010
ncstatesailor is on a distinguished road
xantrex freedom marine 1500 inverter/charger issues
I am currently living on a 34ft Morgan that is equipped with a great little xantrex freedom marine 1500 inverter/charger. The two battery banks that are currently lead acid type.. are at the end of their lifespan and I have purchased two AGM batteries to replace them. I see in the user manual for the inverter that I should be able to hold down the 'invert' button for five seconds.. and then press the charge button... in order to see/select which battery type the unit is set to charge. I need to change it to AGM, but when I hold down the buttons.. nothing on the display changes.
I am wondering if I can not select the battery type until I disconnect the current batteries? I just wanted to make sure my unit's buttons are responsive before I go disconnecting everything.
Does anyone else have any experience with installing these units/ know of any problems with the two buttons on the front?
Thanks!
  #2
Old 04-09-2010
If the batteries are dead, then the inverter/charger may not work properly. IIRC, it will have issues if connected to dead batteries. That is probably why the display isn't working. I'd point out that AGM and Wet Cell batteries are pretty close, so that you can probably hook up the new batteries fairly safely, and then change the settings once the new batteries are online.
You may post attachments
You may edit your posts
Marine Surplus and Consignment Shopping Sue & Larry Gear and Maintenance Articles 0 10-14-1999 08:00 PM
Marine Radios Overview Jim Sexton Seamanship Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Gear and Maintenance Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Her Sailnet Articles 0 09-30-1999 08:00 PM
SEO by vBSEO 3.6.1
