Old 04-09-2010
71Irwin32's Avatar
71Irwin32 is on a distinguished road
Question Bottom Prep?
The bottom on my boat is in pretty good condition according to the divers I've had under it, but it's getting due and will REQUIRE maintenance soon. When I go back to work, I won't be back for at least 6mos.
I've decided on Interlux Micron 66, but wonder what the prep work will involve and I'd like to see what others have done.
high pressure water, sanding....primer?
Thanks!
Old 04-09-2010
What bottom paint do you have on the boat currently??? If whatever paint you pick is not compatible, you'll have a lot more work to do.
Also, I would recommend a Petitt ablative, rather than an Interlux one, since the Interlux ones generally require higher boat speeds to ablate properly. The Petitt ones, like Hydrocoat tend to ablate at speeds as low as 3 knots or so....where the Interlux ones, like Micron 66, often need 6+ knots to begin ablating.
Old 04-09-2010
71Irwin32's Avatar
Wish I knew what paint's on it...lasted a long time.l
What's "ablate" ?
Old 04-09-2010
jarcher's Avatar
jarcher is on a distinguished road
What's "ablate" ?
Ablative paint flakes off in thin layers, to expose more of the active ingredient (like copper). The idea is that as the active ingredients loose their potency, the paint flakes off to expose a new layer of fresh ingredients.
None of it works just sitting around, and as SD said, different paints require different minimum speeds to properly flake off.
In addition, some paints are not compatible with fresh water, others with salt water.
But the most important thing is to know what you are over coating. If you don;t you could have anything from a mess to the pain failing completely. Interlux has a chart on their web site that tells you what preperation is needed based upon what paint is going on top of what other paint.
Helios
Scampi 30 MK-IV
Old 04-09-2010
Technically, ablative paints "ablate" or erode under the water rushing by it when the boat is in motion. They do not flake.
If the existing paint is a hard epoxy paint, then many ablative paints may be compatible with it.
How long have you owned the boat??? If the old owner was responsible for the paint that is on it now, then you should call him/her about it, if you can.
Old 04-09-2010
jarcher's Avatar
Very true, I was just trying to avoid explaining the word "ablate" by using the word "ablate."
Helios
Scampi 30 MK-IV
Old 04-09-2010
LOL...yes, circular definitions are not very useful...but flake isn't really accurate...erode is...
Old 04-09-2010
tager's Avatar
tager is on a distinguished road
Like a bar of soap in the shower.
Old 04-09-2010
jarcher's Avatar
I concede, erode is better than flake!
As for soap in the shower, do you mean before or after it is dropped?
Helios
Scampi 30 MK-IV
Old 04-09-2010
71Irwin32's Avatar
I owned the boat 5-6 mos. The preivous owner did no maintenance, except to have the bottom painted in 2005....by the same yard I'm taking it to. It's a DIY yard, but they also contract work.
I've had two different divers under it, and they both comment on how good the bottom is. The prop and shaft are terrible though.
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom prep on 1986 h23 with iron keel Kids4sail General Discussion (sailing related) 3 01-05-2010 07:46 PM
How long does race bottom prep last? paulmcquillan Racing 5 05-09-2006 06:25 AM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
