04-10-2010
First, 10 AWG wire is awfully heavy, even for an anchor light. Even if you got a 25 Watt light fixture, you wouldn't need 10 AWG. Running the 10 AWG is going to be a lot harder than running 12 AWG, which is a more appropriate size for that run and wattage.
Instead of running the wire, I would run a messenger line with a piece of bicycle chain on it. This will be easier to fish out of the bottom of the mast, since you can retrieve it with a magnet. A good messenger line is about 3 mm or so...
You might want to try fishing the messenger line out through the compression post by using a fish tape with a magnetic end on it. If you can thread a fish tape up the bottom of the compression post, that would really simplify things.
BTW, McLube SailKote works wonders as a wire lube for pulling wire through masts and such.
