04-11-2010
Layup the backing board yourself. The advantage of doing this is you can make the board's the thickness you need. Lighter, smaller gear doesn't require a 1/2" backer board... where as a windlass or deck cleat might.
For small, really highly loaded items, you can even taper the backing board so that the heaviest section is right in the middle to help prevent fatigue and a hard stress line against the deck.
If you want to buy fiberglass cloth cheap for use in backing boards... defender sells boxes of surplus fiberglass cloth in various sizes. I got a 20 lb. box of assorted weights and sizes for $50 or so.
I would use a glass or plastic sheet as the surface, since, you probably want one side to be as flat as possible.
