04-11-2010
Yes, it is that simple to remove/reinstall a Norseman fitting. However, don't forget to use the Blue Loctite compound, which I believe is normally required on mechanical fittings.
When cutting the wire, tape around it and use a hacksaw to cut through it at the tape. This will help prevent you from distorting the wire.
