Old 04-11-2010
WanderingStar is on a distinguished road
Water Filters?
Do you filter your drinking water? The old filter housing cracked, it's not available anymore. Who filters, who doesn't, what do you use? Inline or external? Additives to the tank? Before I installed a cartridge, the water still tested clean. Would you just replace the filter with straight pipe? Thanks.
Old 04-11-2010
nickmerc's Avatar
nickmerc is on a distinguished road
I have an inline point of use filter for my galley. It helps with the varying taste of water from different locations. A buddy of mine filters the water as he fills his tanks. Last season I only used the onboard water for washing dishes and other stuff and used bottled for drinking.
Nick
S/V Blue Bayou
1974 Pearson 30 #517
Old 04-11-2010
Tom Kringstad
tkringstad is on a distinguished road
Originally Posted by WanderingStar View Post
... The old filter cartridge cracked, it's not available anymore. ...
Did the housing crack, or the internal cartridge? As I recall, that shop in Ft. Lauderdale where we got your last cartridge had quite a few of them last year. I think they also had containers with the same form factor. (albeit not the vintage pea green style you have now)
I'm pretty certain we got it at Sailorman New & Used Marine.
350 Southeast 24th Street
Fort Lauderdale, FL 33316-3914
(954) 522-6716
Pacific Seacraft Crealock 31
Old 04-11-2010
wwilson's Avatar
Chesapeake Sailor
wwilson is on a distinguished road
... Who filters, who doesn't, what do you use?
We bought a Seagull filter years ago. It is expensive, but turns "skanky" tasting tank water into very good tasting water. Besides the taste, the filter is fine enough to remove even some viruses. Still, a chlorine "shock" once in a while is a good idea for a water tank.
http://generalecology.com/pdf/pr/SGIVpds.pdf
Wayne
s/v Virginia Dare
Old 04-11-2010
ereiss is on a distinguished road
We've been using a Sears in line kitchen type filter. Probably cheaper than any Marine variety (not cheap anyway). Happy with its impact on galley water taste and smell. However, if you let any water sit for weeks in the tank . . .
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
Old 04-12-2010
(954) 522-6716
Tom, thanks, we did get it there. Of course you are right, it was the housing that cracked, at the top. I need to replace it, or at least put in more line. I'm thinking of a foot pump too.
Old 04-12-2010
Tom Kringstad
Sent you a PM with a link to a housing that I think has the same form factor as your current filter. Since you already have a filter inline with the water systems I would prefer keeping it. The housing for your filter is less than $20, so you won't be out much if it doesn't work.
As for the foot pump, probably a good idea and cheaper than a dentist bill.
Tom.
Old 04-12-2010
Tom.
LMAO. What? I know better than to use my teeth....
Old 04-12-2010
Tom Kringstad
I was referring to the loose morals of your galley spigot and the need to manually prime the hand pump by sucking on it to draw the water. Big risk of chipping teeth doing that out at sea.
Old 04-13-2010
I got it, I was just making an obscene reference to what we called the procedure of pump priming.
Low Cost General Tools Moisture Meter? RhythmDoctor Gear & Maintenance 14 04-24-2011 08:53 AM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Understanding Tidal Currents Jim Sexton Seamanship Articles 0 08-05-2003 08:00 PM
