Old 04-11-2010
eMKay's Avatar
eMKay is on a distinguished road
Hunter 27 revival it's ALIVE! ALIIIIIIVE!!!
So after replacing pretty much the entire fuel system on my boat, i couldn't get it to start, bled three times still no start. When I cranked it for a few seconds on the initial inspection (back in january) I got puffs of white smoke (unburned fuel), this time I didn't so I knew it wasn't getting fuel. Bleed and bleed some more still nothing! A quick google search came up with the suggestion of cracking the fuel line right at the injector, cranking the engine until fuel squirts out, and then trying again. I thought nahh, that can't work! It's got return lines, all the bleeding I've been doing should clear it!
So I tried it, loosen it, jam a screwdriver between the solenoid and starter, crank (took a good 15 seconds) see fuel squirt, re-tighten, turn the key (lol, key...jam screwdriver) crankcranksputterRAAAAWWWWRRRR!!! WOOHOO! run it until the bucket is empty and shut it down. Runs real nice, settles down and purrs nicely.
Now I just need to sand and paint the bottom and it can be splashed. Now I can finally get to work on the rigging and cosmetics. The PSS is installed, this was a piece of cake actually. I added the extra hose clamp on the shaft because I'm looking at this thing, thinking the only thing keeping the boat from sinking is the set screws on that stainless collar. I got room for another one, I might add another too. There is nothing about that in the instruction manual, I think there should be. I have seen people use those stainless collars too.
I also installed the vent line today, this pic was last week.
Prop install - The yard manager told me what to do here, he said put the prop on, without the key, then score the shaft, then take some lapping compound and spin the prop on the shaft for a few minutes to seat the prop, then clean it off and put the prop on with the key. If the prop is below the line you scored you have to shave the key down until it fits. The lapping compound is to make sure the taper is right, and to seat the prop on the taper. Then he said to put the big nut on the outside, which I thought was odd. I walked the yard looking at all the boats, and all the new ones had it this way, all the old shoes had it the other way. So...
Rudder is done too, just waiting for barrier coat and paint. I'll do that when I do the bottom
Siren 17 #1094 "Minuet" (first boat)
O'day 192 #488 "Aria" (second boat)
Hobie Wave #2697 (current boat)
Hunter 27 #716 "Revival" (current boat)
Old 04-11-2010
smackdaddy's Avatar
Last Man Standing
Great work em! It's cool seeing this thing come together. What's your splash date?
BFS Gear: SNers started it....
Old 04-11-2010
eMKay's Avatar
May 15th on or about.
Old 04-11-2010
smackdaddy's Avatar
Last Man Standing
Dude - you have to get some good pics of the inaugural sail. May it be a BFS!
Old 04-11-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Nice work, Em.
Old 04-11-2010
GaryHLucas is on a distinguished road
Brings back memories! I had a 1976 Hunter 27. It looks to me like your rudder ISN'T bent. That's rare on the Hunter 27s I found out. If you have the shoal draft keel the rudder bangs the bottom any time the keel does. My boat had a lot of weather helm, so much that the tiller was splitting from the load. I looked at other H27s in the yard, then got the dimensions from Hunter. Mine was bent back 4". Some in the yard were bent as much as 11 inches! I hung it from nylon slings in a press and bent it back straight. Then I pounded a smaller stainless tube down inside the rudder shaft. After this I could often sail for half an hour or more with no hand on the tiller, it balanced perfectly!
Gary H. Lucas
Old 04-11-2010
eMKay's Avatar
No, it's not bent but it was wet so I had to fix that. Even then I hear they have weather helm that a backstay adjuster will take care of. It's a deep keel so the chances of hitting something are slim.
Miami Boat Show, Catalina,Hunter,Beneteau,Jeanueau Melrna Boat Reviews 38 08-10-2010 12:23 AM
Hunter 27 revival post #3.5 2/9/2010 eMKay Gear & Maintenance 1 03-17-2010 08:00 AM
Hunter 27 revival post #4 2/13/2010 exhaust fix eMKay Gear & Maintenance 1 02-14-2010 07:41 AM
Hunter 27 revival post #2 1/25/10 eMKay Gear & Maintenance 6 01-26-2010 01:31 PM
Hunter 27 revival post #1 1/12/10 eMKay Gear & Maintenance 6 01-13-2010 04:49 PM
