04-12-2010
I would replace as much of the core as possible, while leaving the area immediately adjacent to the chainplate solid glass. Also, make sure fastener holes are properly potted or in the solid glass area.
Is the overhead liner glassed to the cabintop?? Or is the bulkhead glassed to the hull?? If the bulkhead is glassed to the hull, then the reason for the bulkhead being screwed to the cabin overhead liner may be to support the liner. If the liner is glassed to the hull, then the screws may be to support the bulkhead.
