04-14-2010
Originally Posted by Frozensurfer
The soft spots are small but in the planking, should I sand or grind it out and fill it with epoxy/filler to fair it in
Yes, you should address these now. If the spots are very small, then simply filling with thickened epoxy is okay. However, if the spots are large enough to make it feasible, it is much better to drill/route out the area and epoxy in a new piece of cedar. If you will be doing structural damage to the plank by doing this, then the best thing to do is to replace the whole plank.
It is up to you how picky you want to be on a project like this. Ideally, you would deal with every little spot but a lot of people are not willing to spend the time and effort and only tackle the major ones.
