Old 04-14-2010
ThirdCoastSailor is on a distinguished road
Gear shift control cable
I've recently acquired a Catalina 380 and I'm contemplating changing the gear shift cable to make it easier to shift. Does anyone know the length of the cable. Edson says it will be 8' or 10' but not sure which.
Has anyone done this particular bit of work? How difficult is it?
Thanks,
TCS
Old 04-14-2010
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Why do you think it's the cable? There could be several other problems..........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 04-14-2010
BarryL's Avatar
BarryL is on a distinguished road
Hello,
Before changing the cable you should make sure that it is properly routed and then lubricate it with some oil, lithium grease, or something else. Be sure to lubricate both ends of the cable.
Good luck,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 04-14-2010
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
cable change is pretty easy, remove it and take it to your local supplier and they'll match the length
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 04-14-2010
CaptainForce's Avatar
Well, I guess if they're saying that you should see if it's "run right" and they expect you to lubricate it; then you might as well measure it while you're there so you know if it's 8' or 10' and put in the new one. Darn, the work!
Old 04-14-2010
It could be as simple as just a clevis pin is grungy. Go simple first before spending buck$........i2f
Old 04-14-2010
If your going in there, replace it, I've done a few, it's easy, just replaced a shifter cable, a 19' morse was 38 bucks
1978 Tayana 37
Old 04-14-2010
klem is on a distinguished road
I would recommend trying to shift the tranny by hand on it with the cable disconnected. Next, try moving the cable on its own with nothing connected. Then try shifting it with the cable connected to the tranny but disconnected from your shifter. Then hook up the shifter and see how it goes. The force is not going to be the same for each of them since there is mechanical advantage but it will give you an idea of how easily the cable moves.
I have seen several things cause this problem. If the rigid ends of the cable get bent at all, it will be hard to shift. If the cable itself is corroded, it will be hard. Another common thing that I have seen is a worn out shifter (I have not had good luck with the morse units). There are a lot of things that can cause the problem so I would suggest troubleshooting first. Cables are cheap and not a big deal to replace but while you are at it, you might as well fix the problem.
If changing cables, you might consider something other than the Teleflex/Morse units. I have heard really good reports with the cables from Kobelt. I have no personal experience with their cables but have had very good experiences with their shifter and I would expect that there cables are well built as well.
To answer your original question, just pull the old cable and take it into the store with you. If it has a hard to reach run, you might want to pull a line through when you remove the old one to allow you to pull the new cable through.
Old 04-15-2010
Thanks for all the suggestions. Sounds like I have some more troubleshooting to do.
TCS
Old 04-15-2010
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
You should be able to find the information you need printed on the cable. An easy was to route a new cable is to attach a double threaded connector to the old cable, and the other end of the connector to the new cable. As you pull the old cable out through the pedestal (if you have one), you'll be pulling through the new cable at the same time.
Cable gear snatched in Cooper City - Miami Herald NewsReader News Feeds 0 12-31-2006 04:16 AM
Maintaining Safety Gear Tom Wood Seamanship Articles 0 12-21-2001 07:00 PM
Maintaining Safety Gear Tom Wood Gear and Maintenance Articles 0 12-21-2001 07:00 PM
Maintaining Safety Gear Tom Wood Cruising Articles 0 12-21-2001 07:00 PM
Maintaining Safety Gear Tom Wood Her Sailnet Articles 0 12-21-2001 07:00 PM
