Old 04-15-2010
Gorlog is on a distinguished road
Send a message via Yahoo to Gorlog
Outboard Sizing???
Hello, I have a Venture 21 with a waterline lenght around 17',the beam's 8' Light displacement, swinging keel. Would a 9.9hp Honda, weighing in at 108 lbs, be too much? or would a 6 hp weighing 60 lbs. be more suitable? I woulden't mind having the extra power of the 9.9, but the extra weight is my my concern. For one it's much more difficult store, transport and handle. Secondly I concerned that it's too much weight too far out from the center of gravity of the boat, and will affect the boats handing ability when under sail. I do intend to take the boat out in the the Sacramento River, and in the Pacific along Southern Calif., where I may encounter currents stronger than in lakes. Is the 6 hp underkill?, is the 9hp overkill? I don't know, and so I ask you - Thanks for your answers - Gorlog
Old 04-15-2010
ops, posted twice
Didin't mean to post this one twice
Old 04-15-2010
The 9.9 is not only overkill, it would cause the boat to squat, with the bow up... and affect the sailing performance. It would increase weather helm by shifting the COE aft because it is effectively raking the mast.
Old 04-15-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
A 6 is plenty for that size boat. Even a 4 might work.
Old 04-15-2010
75R20 is on a distinguished road
I have a 20' sailboat, with a Honda 7.5 and it is way too much for the boat. It weighs in at 80 lbs. I never open the throttle past the "start" indictator on the twist grip to push the boat at 4.5/5 knts (hull speed). The boat came this way, and I'm looking at a Honda/Tohatsu/Suzuki 5 hp or even a lighter 2-stroke, if I can find one with F N R and charging for the battery. I operate this current motor at such a low speed that it does not charge the battery on the boat, and with the smaller motor it will require more throttle to push the vessel to hull speed so it should be better for charging.
Best of Luck
Kary
S/V Mariah
#49080
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Outboard Sizing??? Gorlog Gear & Maintenance 1 04-15-2010 02:26 AM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Outboard Motor Brackets Sue & Larry Gear and Maintenance Articles 0 09-04-2002 08:00 PM
