Old 04-15-2010
copacabana is on a distinguished road
Sunbrella longevity
I'm just about to lay down a chunk of money to redo all my canvas on the boat and I have 2 options for material: Sunbrella (imported) or a national equivalent made by Alpargatas that seems to last about 5 years. Sunbrella is about 50% more expensive. My question: How long does Sunbrella realistically last in the tropics? How long before it ceases to be 100% waterproof? (I know it comes with a guarantee of XX years, but what is your real experience with it?)
Thanks in advance!
Old 04-15-2010
Zanshin's Avatar
Zanshin is on a distinguished road
I don't think Sunbrella guarantees to be waterproof at all. Even when new, the bottom side of my Sunbrella bimini would wet a paper towel held against it after rain. It won't pour through or drip, but it isn't 100% waterproof. The guarantee is against fading.
I'm on my second set of Sunbrella covers and they hold up pretty well in the tropical sun and heat - but the stitching used on both systems is becoming brittle and losing tension, I need to be careful when zippering up the bimini or dodger to not break the threads. I would be certain that the shop making your canvas uses premium thread/twine and it pays to have everything double-stitched as well.
The canvas on my old boat lasted 6 years in the tropics, removed during the hurricane season and then kept out for the rest of the year. By that time it would drip through after rainshowers and instead of being a closed cloth material you could see light through it. Both the material and cloth had become brittle. I could have applied some 303 fabric guard to make it last one more season, but it was pretty much EOL (end-of-life).
Sunbrella: Marine tops and covers care & cleaning
All of those I've met with canvas problems have complained about stitching rather than about the base material.
Old 04-15-2010
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Sunbrella will last forever if treated well. The problem is the thread that is used to sew the stuff together. The stitching will fail before the fabric. A boat I bought in 1990 still has the original Sunbrella bimini and dodger. I spent the extra money for a UV resistant thread ($350/spool back then). Newer thraed is available now; don't know what the price is now.
Old 04-15-2010
Make sure the vendor uses Tenara Goretex thread or an equivalent when sewing the canvas... it is highly-UV resistant...
Old 04-15-2010
CaptainForce's Avatar
Sunbrella is very sensitive to chafe, but will do well in other respects. Very good advice about the threads,- we've kept some sunbrellabut had it restitched. I've successfully used a brush on Ace Hardware water seal on my sunbrella for years. 'take care and joy, Aythya crew
Old 04-15-2010
FSMike is on a distinguished road
As noted, restitching is a fact of life with any sort of canvas. Sunbrella colors usually hold up quite well with the exceptions of red and yellow.
Sail Fast Live Slow
Old 04-15-2010
Barking Dog
KindOfBlue is on a distinguished road
They are starting to use a heavy vinyl from the trucking industry to make dodgers and biminis in the Caribbean. It actually doesn't look all that bad and it is 100% waterproof from day 1. It will out last sunbrella by many years. I bought some off a sailmaker/canvas guy here in the BVI and I am going to use it to replace my existing chafed, leaky sunbrella dodger. It comes in all sorts of colors, however not as many choices as Sunbrella. Just my 2-cents.
Also - I second the dogs choice of Goretex thread. It will stand up to the UV, however it's more difficult to work with so the canvas guys may not use it unless you ask.
Craig
Old 04-15-2010
Thanks for the answers. I was aware of the thread issue and I'm supplying the canvasmaker with my own thread. I can see that applying a protective spray seems to go a long way to improving the water resistence of the material. Now I just have to find a product here like 303! anyone know what's in the stuff?
Old 04-15-2010
tommays's Avatar
What ever EXTANG uses for truck bed Tonneau covers
The stuff holds up to sun/rain/snow and getting 70 MPH wind 365 for 7 years
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-16-2010
14432's Avatar
14432 is on a distinguished road
303 Fabric Protectant seems to be a well-guarded secret. West Marine has duplicated the 303 Vinyl Protectant with pretty good results but they don't have a similar product for fabric.
There are some alternative products - like Aqua Tite - Sail-Rite carries it
Sunbrella Fabrics, Sailcloth, Canvas and Sail Hardware, Gill Foul Weather Gear and More!
Weight for sunbrella hatch cover LakePirate Gear & Maintenance 4 11-04-2009 09:19 AM
Experience Using Gortex Thread & Sunbrella? geoffschultz Gear & Maintenance 3 02-06-2007 07:02 PM
Winter care of Sunbrella svzephyr44 Gear & Maintenance 4 11-14-2004 05:15 AM
How to clean Sunbrella fabrics? KPBaker Gear & Maintenance 2 05-21-2002 07:32 PM
