04-15-2010
If you own a boat, you're eventually going to have to learn how to do it... Buy Don Casey's This Old Boat, 2nd Edition. It has a lot of good information in it...
West Systems' website also has a lot of good information on it.
As for materials, I'd recommend using epoxy from Progressive Epoxy Polymers in NH, epoxyproducts.com, and the fiberglass from fiberglasssite.com.
The reason for using epoxy resin, rather than polyester or vinylester resin is that the epoxy resins have the strongest secondary (adhesive) bonding characteristics and will result in a stronger repair for most novice builders.
It is a good idea to glass in the benches on both the top and bottom to make the strongest repair.
Originally Posted by mceveritt
Thanks for the response. This definitely sounds like the way to go... Though I have never laid fiberglass before which is kinda why I am trying to avoid it...
