04-15-2010
Originally Posted by Freesail99
You can also use silicone to make a mold of your nonskid pattern. I have seen that done and it works.
I would use a rubber compound rather than silicone. Silicone can be a problem, since it can leave oils behind that make painting or bedding hardware to the fiberglass later a real PITA.
