Mast Repair? Sleaving/Lengthening? - Page 3 - SailNet Community
post #21 of 25 Old 09-10-2010
Mast riser
Hi I have the same proplem with my 15 meter aluminum mast. I have a hairline crack of about 15 cm on port and starport side of the mast and i been told the best solution would be to cut out the 15 cm piece and raise the maststep.
Would that mast riser be working for me? Cun it be made for my must as well and what is the cost?
Thanks
George
WebSurfer3000 is offline
post #22 of 25 Old 09-10-2010 Thread Starter
Sunsets and Warm Beer....
LandLocked66c's Avatar
Thanks
George
Not sure which mast riser you are referring to. I'm assuming the crack is at the base of your mast?
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is online now
post #23 of 25 Old 09-10-2010
It would help if you said what boat you had. Also, what works on the mast of a 25' boat is not necessarily going to work on the mast of a larger boat. The stresses involved are different.
Thanks
George
sailingdog is offline
post #24 of 25 Old 09-11-2010
I have a 43 ft steel boat with a 50 ft mast. It has a hairline crack 6 inch long of at both sides at the base of the mast.
You can see pictures here:
Hairline crack on mast
I need to take out that plack at the base as well.
Any sugestions?
post #25 of 25 Old 09-11-2010
catamount's Avatar
Any sugestions?
As suggested in the other thread, I think removing the insert, cleaning everything up, and then getting the cracks welded is probably your best bet. When you put the insert back in, make sure that it is some how electrically insulated from the mast itself, either by coating it liberally with Tef-Gel or perhaps wrapping it with teflon tape -- this in case the corrosion that caused the cracking is due to a dissimilar metal situation. You may need to grind the sides of the insert down a little bit to make it a hair smaller to give room for this insulation...
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
catamount is offline
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
