04-16-2010
That's actually not a bad way to do it. A block of PVC cut to fit the hull would work too. You could also mount the transducer inside the boat, provided the boat has a solid fiberglass (not-cored) hull. This has the added benefit of avoiding drilling a hole in the boat's bottom.
To check, use a plastic baggie filled with water and try the transducer in various spots on the hull in the bilge. Once you find a spot that gives a clear signal... glass a 4" PVC tube into the spot and put a cleanout fitting on it... add the transducer to the cleanout cap and fill with mineral oil.
