Curious about mast unstepping procedure - Page 2 - SailNet Community
post #11 of 14 Old 04-19-2010
On most boats I've been on, the coins are encapsulated in epoxy..so no electrolysis concerns, and Charon isn't bothered by the epoxy.
Originally Posted by paulk View Post
What about electrolysis with a copper or silver coin under there? Maybe an aluminum coin - an old franc piece- or something plastic from a New Orleans Mardi Gras celebration would be better? I have to think there's some sort of raised center that the mast fits over or around, which keeps it from moving.
sailingdog is offline
post #12 of 14 Old 04-19-2010
STARBOARD!!
KeelHaulin's Avatar
If you look at the line drawings and photos of the N-28 MKII on capitalyachts.info it appears that there is a heavy wood post on the corner of the bulkhead, at the door to the head. This is the compression post that transfers the mast compression load to the hull. On models with an aft head this compression post is located in the middle of the drop-leaf table. On the mast step there is an extrusion inside that keeps the mast from moving laterally when being stepped; but once the shrouds are tensioned the mast is under compression load and would not move laterally even if you tried to push it off the base.
KeelHaulin is offline
post #13 of 14 Old 04-19-2010 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
Yep, I have seen that wooden post by the head. OK, now I know what I'm looking at.
I guess there's no way to get the mast down at the slip, as there's just not enough distance in any direction to ease it down. I guess you'd have to take her into the lift slip and drop it there.
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #14 of 14 Old 04-19-2010
Tartan 27' owner
CalebD's Avatar
It is likely easiest to unstep your mast by getting your boat near a crane of some kind. The height of the crane need only be a few feet above the spreaders.
Our club has a human operated crane on the dock with purchase for doing just this while the boat is in the water. Calm days are best for this obviously.
You should not have to haul the boat for this procedure.
Everybody has one:
CalebD is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Mast types...? Through deck on deck...? marinesniper General Discussion (sailing related) 41 02-02-2007 09:15 AM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
