Old 04-17-2010
ambianceack is on a distinguished road
dodger pins?
We are missing two of our dodger pins, if that is the correct term, and was wondering what the actual name is and where to purchase them? These are the pins that are screwed into the deck that holds the dodger in place. Any thoughts? If necessary, I can post a picture tomorrow.
Thanks in advance.
Old 04-17-2010
Sabreman's Avatar
Sabreman will become famous soon enough
I think that you're referring to a stud fastner. Try Sailrite.com
Lift-The-Dot Machine Screw 3/8" #8-32 - Key Q
Personally, I took mine out and replaced them with this:
Common Sense (Twist Lock) Double High 2 Screw Base Stud Nickel Plated Brass
Either way, Sailrite will have what you need.
Sabre 38 "Victoria"
Advise on dodger windows please? SanDiegoChip Gear & Maintenance 15 04-14-2010 05:53 PM
Mounting solar panel on top of dodger hardware? SanDiegoChip Gear & Maintenance 14 03-05-2010 11:24 AM
hard dodger vs. soft ktuthill General Discussion (sailing related) 15 10-01-2009 12:31 PM
Dodger frame with solar panel .045 or .062 thick? SanDiegoChip Gear & Maintenance 8 09-30-2009 01:56 PM
thru-hull electric connector - at least 13 pins skysurfer Gear & Maintenance 2 06-28-2006 09:07 PM
