04-18-2010
Is that cap threaded on the inside all the way to the top ? If so, replace the fitting at the bearing and the line ( with a clamp ) clean the res base, fill the cap with grease then replace it, open the valve at the bearing and twist the T-handle on the grease reservoir forcing the grease though the line to the shaft bearing.
Me thinks
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
