-   -   How to remove varnish & sealant from non-skid? (http://www.sailnet.com/forums/gear-maintenance/63974-how-remove-varnish-sealant-non-skid.html)
mrybas 04-18-2010 07:54 PM
I am trying to remove varnish and old sealant that is on the non-skid gelcoat. What is the strongest cleaner that will not do damage to the gelcoat?
poopdeckpappy 04-18-2010 08:17 PM
Try citrus gel or soy gel or lacquer thinner ( none will hurt the gelcoat )and a scrub brush
PorFin 04-19-2010 07:37 AM
Any paint stripper will handle the varnish, and won't damage the gelcoat. I'd just make very sure that it IS gelcoat before I starting slopping stripper around.
The sealant's gonna be a lttle different. I'd first try to carefully remove it with a razor blade scrapper. Depending on what type of sealant you're dealing with, you may need to resort to chemical warfare. I've had luck getting polysulfides off with acetone and PB Blaster. 3M General Purpose Adhesive Remover may also work. If it's 3M 5200, you'll probably need to resort to DeBond 2000.
http://store.hamiltonmarine.com/prodimg/MFA-4.JPG
