-   -   Indentifying Mystery Hardware (Mystery to me anyway) :) (http://www.sailnet.com/forums/gear-maintenance/63994-indentifying-mystery-hardware-mystery-me-anyway.html)
krozet 04-19-2010 02:32 PM
So I have some questions for all you experts out there (those that are not sailing in the AMAZING weather). I am trying to identify a few parts on my boat that seem to be eluding me right now.
Any Simpson's fans out there? To quote Dr. Nick Riviera as Homer is about to go under for his heart bypass surgery...
"What the hell is that?"
http://img687.imageshack.us/img687/8780/14421515.jpg
A & B - are the same things just offset symmetrically on the front of the mast. There is a ring on the inside that spins and I have no idea what they are for.
http://img404.imageshack.us/img404/8872/54623999.jpg
C - is some sort of traveler that runs on a track on the front of the mast. It goes about 1/2 way up the mast. For the life of me I cannot figure out what runs up the front of the mast unless its just an elaborate way to run up the courtesy flag.
http://img340.imageshack.us/img340/2290/59643246.jpg
http://img504.imageshack.us/img504/9402/64165955.jpg
D - I think is a sampson post? I tie off the anchor rode to this when anchoring?
E - Scares the crap out of me... The top is spring loaded to hold it shut but there is an opening in the side of it even when it is closed. When you open it there is a LARGE hole that leads down to a space in front of the v berth.
F - Also leads to the same space in front of the v berth.
So here is the space in front of the v berth, obviously the anchor locker... F I think I understand as I run the anchor rode into as I haul it in but I still don't get what E is?
Looking from the back of the berth forward.
http://img594.imageshack.us/img594/2061/64892723.jpg
Sticking camera into the anchor locker looking up.
http://img59.imageshack.us/img59/4812/94346882.jpg
Back to the unknown.
http://img534.imageshack.us/img534/8978/82412092.jpg
G - due to its proximity to the head & holding tank I think this is the holding tank vent?
http://img43.imageshack.us/img43/3523/89740738.jpg
H & I - Setup for reef points I assume...
Thanks for any info;
Robert
smackdaddy 04-19-2010 02:45 PM
78 Attachment(s)
I'll try some guesses:
C - is a spinnaker/whisker pole connection thingy - and I bet A/B are either for spin guys or block anchors for same.
E/F - definitely for anchor rhode. I'd guess at some point your boat had two anchors. E looks to be for line only - not chain. Either that, or maybe the spring loading lets the chain come in and out, then locks down on a link for backup?
G - that would be my guess (mine's on my bow just under the rail). Is there a vent line running to it?
H/I - definitely look like jiffy reef blocks to me (we have them on our boom)
Total guesses.
DwayneSpeer 04-19-2010 02:50 PM
Yes
I vote for Smackdaddys guesses.
CalebD 04-19-2010 03:02 PM
C - yes, attachment point for spinnaker pole. You must have a topping lift for holding the spin pole up?
A,B - these could be meant for running a 'down guy' to the spinnaker pole which would keep it from moving higher then the topping lift setting. One for either side.
G - could be your holding tank vent. I normally see the holding tank vent mounted outboard, high on the free board. If that is the holding tank vent this location may allow you to sniff the gases of the tank while sitting in the cockpit. With the vent mounted on the side of the boat you may not smell anything. If it is the vent make sure that fitting is clear.
sailingdog 04-19-2010 03:12 PM
Those may be eyes for stowing the jib and spinakker halyards when not in use...or the spinakker pole lift and downhaul lines.
This is a spinnaker pole ring. Typically, they have it on a track so that you can match the pole height to the clew height on the spinakker.
E is a chain pipe for an anchor rode. The slot is to accommodate the chain, as a link will probably fit in the slot fairly well. You can see the rust from the chain links leading towards it... D is a samson post. I hope it has a very heavy backing plate beneath it. F is also a chain pipe, probably for a nylon rode, rather than chain. One is probably for a primary anchor rode, the other for the secondary.
I'd point out that usually is a door or panel closing off the anchor locker, and that it should have a drain at the bottom to let any water that gets into the anchor locker drain out. It would also be a good idea to glass the bottom portion of the opening closed so that the rode and any mud/water that come into the compartment are more easily contained.
Doesn't look like you've got a decent backing plate on the sampson post...However, there may be a glassed in backing plate, but my guess is that the area where the sampson post and round chain pipe are located are probably in a glassed in plywood core, rather than a solid fiberglass deck with a glassed in backing plate. Should be checked thoroughly to make sure the plywood, if it has plywood in there, is not rotting.
The wiring in the anchor locker should be encased in wiring loom to protect it from chafe and secured to the underside of the foredeck.
Sure looks like a vent. Could be for water tank or holding tank...but if the proximity to the holding tank is closest, it is probably for that.
http://img43.imageshack.us/img43/3523/89740738.jpgH & I - Setup for reef points I assume...
Robert
Yes, most likely, and the sheaves are shot...need to be replaced.
smackdaddy 04-19-2010 04:58 PM
78 Attachment(s)
Man, am I good or what!?!?!?!
tomaz_423 04-19-2010 05:20 PM
what.
smackdaddy 04-19-2010 05:26 PM
78 Attachment(s)
What?
Heh-heh.
