How tight should shrouds be? - Page 2 - SailNet Community
post #11 of 13 Old 04-21-2010
Thanks Rich for the reply. I made a copy of your response to have when I re-tune the rig. I don't go through it that often and without an adjustable back stay I can't adjust easily while underway.
Dee #448
lancelot9898 is offline
post #12 of 13 Old 04-21-2010
RichH's Avatar
Its quite easy to go forward and adjust the forestay tension ....just 'ease it'. I find when cruising its the simplest and most effective way to 'balance' all the tensions.
But I insist on a clubfooted staysail .... and I wont go there because of all the controversy about the 'safety' of a clubfoot.
RichH is online now
post #13 of 13 Old 04-21-2010
ASA and PSIA Instructor
Originally Posted by RichH View Post
Simply looking to see if the leeward shrouds are loose/slack/etc. when on a heel is ........ 'nothing' sensible.
To each their own... over many years of racing and cruising, I've found setting the rig by eye to work fine....%s mean nothing if the mast isn't in column, and if the mast is in column, why mess with gauges? I admit to using a Loos gauge on one designs for the convenience of quickly re-tuning at the dock.
sailingfool is offline
do spreaders need to be bolted tight? dnf777 Gear & Maintenance 24 03-02-2010 05:29 AM
terminal replacement for the shrouds sailhog Gear & Maintenance 11 11-25-2009 02:05 PM
Synthetic shrouds capedory30 Gear & Maintenance 2 02-10-2009 08:26 PM
Stays .. Losing Your Mast ... wind_magic Seamanship & Navigation 50 10-21-2007 01:07 PM
Tight budget hasn't slowed sailing team (Milwaukee Journal Sentinel) NewsReader News Feeds 0 06-25-2006 11:15 PM
