04-19-2010
Originally Posted by bljones
why the hell would you want to taper a 9" radius around a 3/4" hole?
To create a proper 12:1 taper to spread the loading of the repair over the hull with. This prevents the repair from having a hard edge and causing future fatigue and stress related problems, since the repair, if made with epoxy resin, is often stronger than the original hull.
In any event, I would use a die grinder with a cone burr rather than a 4" angle grinder for the heavy work, then change to a small detail sander to finish up.
Die grinders are awfully good at chewing up a lot of fiberglass really quickly, and too quickly to control the taper well. I seriously doubt that you really need more than 60-80 grit...
