Old 04-20-2010
Redline4Life is on a distinguished road
Steering cables...
Hey there,
I have yacht specialties steering cables/chain and was trying to get some replacement cable. Unfortunately, because yacht specialties does't exist anymore, I can't find the swaged fitting which connects cables to the chain. The swaged fittings I COULD use would have quite a bit of play in them which obviously I don't want. Any thoughts? I'm trying to avoid buying the Edson system where the chain is permanently swaged to the wire rope.
Much Obliged,
R4L
Old 04-21-2010
Hollen is on a distinguished road
Steering repair
Any rigger can supply you with the proper wire with a “crimped” eye. Take your old one with you and it is a ½ hour job. As for a “swaged” to chain connection, which you said you have, most other steering systems have a chain link to eye connector with a pin fitting that connects the eye to the chain (Edson’s come to mind). Take a look at this.
Wire Rope Kits : Edson Marine Store
Buy just the fitting and make up your own. The simpler it is made, the simpler it is to repair, as I found out in Mazatlan.
Old 04-12-2012
penchev is on a distinguished road
Re: Steering cables...
Hi R4L
Where are you now? I think I know your boat in Auckland, I have been on board once with my wife and Keiran the agent and I may be want to buy her.
My numbers are:
+64 9 5552780 evenings only, +64 815431, extension 5189 during the day, +64 210318120 at any time.
Boris
Steering System Spring Checkup Tom Wood Gear and Maintenance Articles 0 04-26-2004 08:00 PM
Steering System Spring Checkup Tom Wood Cruising Articles 0 04-26-2004 08:00 PM
Steering System Spring Checkup Tom Wood Her Sailnet Articles 0 04-26-2004 08:00 PM
Checking the Wheel Steering System Will Keene Gear and Maintenance Articles 0 07-31-2002 08:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
