Old 03-03-2003
adieu is on a distinguished road
good location for seacocks?
Hi, I''m reinstalling a head that the former owner removed to install a double berth. The old seacock holes were also glassed over.
I have an idea where I want to put the new holes, but would like opinions. I''ve posted pix and descriptions at http://www.adieu.nu/head.htm
Can seacocks be too far forward? Any problems I might encounter? Is it possible to determine the thickness of glass without drilling?
Any thoughts appreciated.
Jim Burgoyne, s/v Quiver, Phuket, Thailand
Old 03-05-2003
pirateofcapeann's Avatar
pirateofcapeann is on a distinguished road
In light of your current additions to the message boards, I would suggest that you only add 2 holes!
A friend of mine had the inlet for his head Tee’d into the drain for his sink. This through hull was just aft of the through hull for the outlet for the head. This was a very unpleasant arraignment indeed. The exhaust from the head would get sucked right back up into the inlet and the head always smelled foul.
If you do need to re-install a head, put the intake on one side of the hull and the outlet on the other. Chances are that the original holes would be a good location. I would bet that you’ll find about 3/8 to ½ inch of glass there.
That said, before you go about the process of re-installing a head of this type, you should consider the legal ramifications. I''m not sure how they go about it there in Thailand but here in the States, this may not be such a good idea! I’ve used a Porta-Potty aboard my boat for the past 12 years or better. While it’s been a hassle at times, it’s been better then the alternative of paying the fines.
Pi
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 116 09-04-2011 08:05 PM
good location for seacocks? adieu Gear & Maintenance 0 03-03-2003 09:48 PM
good location for seacocks? adieu Gear & Maintenance 0 03-03-2003 09:47 PM
good location for seacocks? adieu Gear & Maintenance 0 03-03-2003 09:43 PM
good location for seacocks? adieu Gear & Maintenance 0 03-03-2003 09:01 PM
