04-21-2010
The terminals change over time. I have 2 Iotas...DLS45/IQ4 and DLS55/IQ4. Both have slotted bolts. Slip the charging cables in, tighten with a screwdriver.
I note that some dealers are selling special connections, so the terminal types may have changed significantly. See, e.g., IOTA Battery Chargers
Part-way down the page you'll see special lugs for $2.75 each. Don't know if these will fit your model.
Don't skimp on wire size or quality.
Don't forget you need a fuse or breaker on the positive wire; for a DLS55 you need something in the range of 70-75A. ANL fuses are convenient. So, too, are the MAXI fuseholders/fuses by Blue Sea Systems...they'll take a 70A fuse.
Best to install an AC outlet near the charger, and plug it in.
Bill
