Old 04-22-2010
johnnyandjebus's Avatar
johnnyandjebus is on a distinguished road
flush mount bolts?
Hello all
Currently my cockpit floor is a sheet of fiberglass that sits loose. There are bolt hole to secure it but I prefer to leave it loose for quick access to the engine. I would like to secure using some type of quick release flush mount bolt system, can anyone provide me with an online resource for this type of product?
Thanks,
John
Old 04-22-2010
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
Expensive, but should fit the bill: PYI Inc. Max-Prop PSS Shaft Seal Seaview Radar Mounts R&D
These are generally used to latch down cabin floorboards that access the bilge for offshore work.
Old 04-22-2010
I would definitely recommend securing it... since, if you get knocked down right now, you could lose it over the side... and that would leave your engine wide open to water flooding in...not a good idea..
A better idea might be to hinge the cockpit sole so that you can open it like a trapdoor.
Old 04-22-2010
merc2dogs is on a distinguished road
I've never been a fan of hinges for things that need to seal water tight. The sealing action itself needs pressure, and most hinges aren't able to take the loads required in the direction it's applied. Then when it's open, you often have the 'door' in the way of what you're trying to do.
My preference would be to use the fasteners SVCarolena linked, or google dzus fasteners, available in many styles and materials. Many have captive fasteners with D-rings so you have easy tool free opening and don't have to worry about lost fasteners.
They also have them with toggle type handles, where you secure them then press the toggle down for quick tight sealing.
Ken.
Old 04-22-2010
Properly installed hinges that are through-bolted do allow you to seal a hatch. Also, there are hinges that allow the door to be removed if necessary.
Ken.
Dr. Diesel, Foley Engines, and me... skipgundlach Diesel Engine Forum 34 06-13-2011 06:00 PM
Keel Bolts Repair/replacement chartscharts Gear & Maintenance 11 08-07-2006 03:53 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
keel bolts on a P323 jnorth Gear & Maintenance 2 02-18-2002 04:16 PM
