04-22-2010
crap... I think you're right about that...
Originally Posted by kwaltersmi
I've got the regular/normal sized Echomaster. Most reviews rate them well when mounted high in the raincatcher position. If I remember correctly, the emergency Echomaster that you have is a bit smaller and is made of foam board covered with foil, as opposed to the all-metal construction of the larger "normal" Echomaster.
