Changing Coax in the mast. - SailNet Community
post #1 of 8 Old 04-23-2010 Thread Starter
1977 Morgan OI 30
Joesaila's Avatar
I'm hoping someone has done this or has some tips that may help. I am changing coax cable that runs inside my mast. I'm doing it w the stick up and will be using a bosuns's seat. The plan is to use a thin rope at the top, connected to the cable and then to haul it out at the base and then pull the new cable through. This will be done w the boat on the hard...but I gotta do it.
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Joesaila is offline
post #2 of 8 Old 04-23-2010
When we did a similar job on my boat we found that the in-mast wires were all cable tied together every 600mm or so all the way down the mast. Rigger wound up having to pull the entire cable bundle out and lower it to the deck, then pull it back up so we could re-pull the wires in using messengers.
I hope your experience is more positive :-)
rbarkas is offline
post #3 of 8 Old 04-23-2010
tommays's Avatar
The on the HARD part is pretty much a deal killer from a saftey standpoint
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 8 Old 04-23-2010
I replaced the coax cable in the mast with a larger diameter cable some years ago and if memory serves me correct someone was at the top of mast with me at the bottom pulling on the cable. (keel steped mast) I think that we taped the new cable to the old and let gravity take everything down just requiring a careful pull when the new cable exits the mast. We could have used a small line and let it down that way too. Thinking about it more I think the small line was used since we could secure the new cable better to the thin line vs securing it directly to the old cable plus the thin line helped pass the new cable through the small diameter hole in the bottom of the mast. The boat was in the water BTW.
lancelot9898 is offline
post #5 of 8 Old 04-23-2010
Joe-
Do not go up the stick on the hard. It is really dangerous, and if the boat starts to tip, it isn't going to stop, and you're going get really seriously injured. Either hire a bucket truck or wait until you're on the water.
sailingdog is offline
post #6 of 8 Old 04-23-2010
Joe-
That is the tip that helps, that is the #1 tip, read that tip, it is the one that must be understood first.
I got other ideas but they do not matter, that is the one, that one there, that tip is thee tip.
Have faith that the oceans are going to rise and flood the world, that plague and pestilence brought on by Climate Change is going to punish us for not believing. Please do as they say it is our only hope. :P
Architeuthis is offline
post #7 of 8 Old 04-24-2010 Thread Starter
1977 Morgan OI 30
Joesaila's Avatar
arhgggggggg
OK, I got it. I'll do it on the water. I don't want to be a human domino or bug on a windshield. Thanks!
Cary Grant
Joesaila is offline
post #8 of 8 Old 04-24-2010
no no no..I gots the answer man!!! Did mine last summer aand stuck everywhere tryin to thread my new cables...even with the mastdown...until an old man came with his hoover and guess what...2 secs. later and theres my sailing thread with a screw on the head right out the bottom..I gave him a monte cristo#4 for his trouble.I called him a geniuos afetr my weekend of cussing ...So climb your mast,forget the warnings from the nannys and drop that nut. Hook up your hoover end and suck it down..or have someone on the bottom so you dont have to climb 2x..oh,the hooror..of course sew the ends together(coax and sailing thread and tape the connection...must use strong thread!!
ps. Use a very light weight on the end,I think I just used a litle screw..good to test it out horizontals as your limited when you get crowed.oh,just rig a good attachment at the bottom to reduce air escape but dont think it matters. You got gravity on your side ,too. My old mast was on the hard and couldnt keep that nut fom gettin sucked!!!!
kredit is offline
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
