Old 04-23-2010
preservedkillick is on a distinguished road
What is considered too much play in the cutlass bearing
I need to make a decision on replacing my prop shaft. The concern is that the shaft is worn in the area of the cutlass bearing. The shaft constantly measures .8725 diameter down the length of the shaft until you hit the area where the shaft rides in the cutlass bearing - the lowest reading is .8650 ~ a difference of 7.5 thousandths.
With the inside diameter of the new cutlass bearing @ .8810 there would be a difference of 16 thousandths for play. Is this considered excessive? Lead to vibration? Are we talking "Princes and the Pea" here? Or am I likely to notice a real difference with a new prop shaft?
jeff
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 04-23-2010
DrB DrB is offline
DrB is on a distinguished road
I think the max dimension you want is 1/16th....
of inch total play so 0.0625 or 62.5 thousands. Most folks say that, with the shaft centered, if you can get more than a 30 mil shim between the CB and the shaft, you should replace.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
Old 04-23-2010
Gene T's Avatar
Gene T is on a distinguished road
I am surprised the cutlass is larger than the shaft. I have never measured one but the last one I put in had an interference fit. I replaced one once where I could still move the shaft by a noticeable amount afterwards and that cutlass lasted many years. More play just means it will wear out faster. How much do you motor? It may not really be an issue.
Currently in Long Beach, CA
Old 04-23-2010
I just remeasured the cutlass bearing ID again. A new Johnson Duramax. I get anything from .8870 to .8800. Tough to measure rubber accurately. I'm starting to think I'm fussing over something that's insignificant. I'm still a ways from 1/16th.
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 04-23-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
7-8 thousands wear is nothing to worry about. You'll be fine.
Old 03-30-2011
Kutter is on a distinguished road
Thats still within clearances for Maritex water lubricated shaft bearings.
in mm
For a 22.00mm shaft (0.8661)
New clearance is ID 22.12 - 22.22 (0.8709 - 0.8748)
Replace when it gets to ID 22.55 (0.8878)
There is a calculator on our website where you put in your shaft size and it gives bearing clearances.
removing rusty coupler set screws victoria28 Gear & Maintenance 22 01-29-2010 12:35 AM
Repairing Cutlass Bearings Mark Matthews Gear and Maintenance Articles 0 05-07-2002 08:00 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Loose Cutlass Bearing Sue & Larry Gear and Maintenance Articles 0 02-18-2002 07:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
