Old 04-23-2010
ThirdCoastSailor is on a distinguished road
Leaky faucets
My faucets are leaking at the handles but there aren't any screws in the handles so I can't figure out how to get them off to replace the washers. Any suggestions?
Old 04-23-2010
Freesail99's Avatar
Freesail99 will become famous soon enough
There may be a ring nut below the sink and counter. Did you look there?
Could it be that the washer is located within the water spout and not the handles?
S/V Scheherazade
Old 04-23-2010
No, I haven't looked under the sink but I will this weekend.
Thanks
TCS
Old 04-24-2010
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
Have you tried just pulling the handles off? Maybe they're push on/pull off handles
Old 04-24-2010
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Chances are that the screws are under the the accent cap on the handles. try pop'n those out, then replace the whole valve, they're really inexpensive
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 04-24-2010
I don't think there are any screws under the accent caps. The handles really tool like a single piece. I think JiffyLube may be right, just try to pull them off. I'm going down to the boat tomorrow so I'll give that a try.
TCS
Old 04-24-2010
JiffyLube's Avatar
Grasshopper
Usually the screws are under the accent caps like you say, at least the ones I've come across.
Old 04-24-2010
Yeah, most the ones I've seen either pop out or twist out, then you pull the handle off and have access to the valve, but then most the stuff I've delt with is obsolete
1978 Tayana 37
Old 04-25-2010
JiffyLube's Avatar
Grasshopper
I'll be interested in hearing what ThirdCoastSailor has to say about his facets.
We went out sailing in the bay yesterday, and before we went out I checked the bilge for more water. No more water in the bilge, so I guess I was right about the water heater leaking...add that to my list to fix.
Old 04-25-2010
hellosailor's Avatar
A posted picture would be worth a thousand words.
Leaky cabin roof- C&C34+ hedtrp Gear & Maintenance 3 04-30-2010 01:04 PM
Replacing Faucets PBzeer Gear & Maintenance 5 05-05-2006 12:41 PM
leaky cabin windows asailor Gear & Maintenance 2 10-21-2002 03:40 PM
leaky shaft log captbruce Gear & Maintenance 1 09-06-2002 04:44 PM
Leaky transmission Volvo Penta 2003 ekhar Gear & Maintenance 0 08-15-2002 05:54 PM
