Old 04-25-2010
weephee is on a distinguished road
Companionway Hatch
I have removed my companionway cover/hatch to refinish it and have noticed that the plastic sliders between the hatch and the top of the cabin have worn away. They are small in diameter, about a quarter the size of a penny, and I can't seem to find new ones in my area. Can anyone tell me where to get them or if there is something better to use. Its a lot of work removing all the hardware in order to remove the hatch if I have to replace these little sliders on a frequent basis. Thanks
Larry
Old 04-25-2010
Gary M's Avatar
Gary M is on a distinguished road
A picture and make/model of your boat would help.
Old 04-25-2010
It is a columbia 27 ' I will post a picture later this morning. Thanks
Old 04-25-2010
stevemac00 is on a distinguished road
They should last a very long time. Do a google search for nylon glides. Here's an example: Double Nail-on Glides - Rockler Woodworking Tools
Remove the nail and epoxy them on.
Steve
PSC 31 #84
Talisman
Old 04-25-2010
You can probably replace the little sliders with a long piece of delrin or starboard. By spreading the force over a larger surface area, it will likely reduce the wear.
Old 04-25-2010
harbin2 is on a distinguished road
Woodcraft stores have rolls of sticky backed teflon tape. I got some for the same application and it worked very well.
Old 04-25-2010
heinzir's Avatar
Junior Senior
heinzir is on a distinguished road
Here's something that works quite well
Japanese Glide Tape
http://www.apsltd.com/c-4492-japanese-glide-tape.aspx
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
Old 04-25-2010
Thank you for all the ideas. Harbin2, how long have you been using the teflon tape. I guess the Japanese Glide tape would be the same thing.
Old 04-25-2010
For a year. Actually, I needed something to elevate the hatch a little since it was rubbing on the cabin top at the foward end. The tape is about 1/32 of an inch thick. It is working well.
Companionway hatch for E-27? captainbrad Ericson 5 09-25-2011 10:46 PM
Companionway Hatch Replacement danohayes Gear & Maintenance 9 10-23-2008 09:46 AM
Wauquiez Hood MK I Companionway - pros and cons garymcg Boat Review and Purchase Forum 0 10-17-2006 02:53 PM
Wood vs. Plexi - Companionway Hatch Boards lightyear22 Gear & Maintenance 7 03-16-2006 09:06 AM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
