04-25-2010
I would recommend using Stainless Steel, rather than bronze, since bronze is softer and won't stand up to the wear as well. Harder metals are better for rubbing strakes, as they're less likely to get damaged. If a rubbing strake gets damaged, it can easily chafe or damage the lines rubbing it.
