04-27-2010
Originally Posted by kwaltersmi
Our boat has a teak cockpit grate, which to my knowledge has never had any oil or other sealer/protectant applied. It currently has the gray weathered looked look of natural, uncoated teak. It's great underfoot, with a smooth natural non-slip feel.
Is there any reason to apply a couple coats of teak oil to the grate? I realized weathered teak provides excellent non-skid and the gray color doesn't bother me at all. However, I was thinking the oil might make the grate last longer...but then again, the oil might also make the grate slippery. Any thoughts or opinions?
Teak that has become grey has been UV burned ... destroying the topmost wood cells. In several years of UV exposure the teak surface will become badly eroded. Teak is now costing .... approaching $40 per board foot; so, protecting it is very prudent IMHO.
Teak Oil usually doesnt have sufficient UV retardants and if applied 'thick' will oxidize and eventually turn dark; plus, it can get quite slippery when wetted.
Your situation is probably best served by an application of a TEAK SEALER. Many have pigmentation additives that help to retard the inevitabale UV destruction. For high wear, high traffic areas I prefer SEMCO (goldtone).... for other areas I prefer a 50:50 mix of Semco goldtone and Teak Wonder. Such (minimum of 2 wet coats) will last about one full season .... less if the sealer is constantly washed by boarding 'green waves'.
Rx: Etch/scrub the grate with TSP to get rid of the UV damage ('grey'), then bleach with Oxalic Acid, and then apply a minimum of 2 coats of Teak Sealer. :-)
