04-28-2010
Partially filling it will at least let you know if you have any leaking hoses and such... but won't really test the integrity of the system as a whole...only filling the tank entirely would do that, since there could be a leak higher up in the water tank that would not be discovered until the tank is filled completely.
As for treating it... follow Peggie Hall's directions.
Originally Posted by QuickMick
Ive got a pressurized water system that is currently dry. Any tips on what I should do to make sure it is clean/working before I fill it? Maybe just partially fill it to check integrity? thanks
